76 Pinto Wagon
Date: 07/08/2020 05:44 pm
nos core support
Date: 01/03/2020 09:39 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 05/13/2021 05:33 pm
Date: 12/30/2022 01:30 pm
Date: 11/02/2019 10:25 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
  • Online today: 295
  • Guests: 168
  • Total: 168
To: 2.3 Pinto oil pan and pickup needed (make sure you know)
Started by Wittsend, January 07, 2013, 05:11:21 PM
72pair
Most I've seen take a 8mm 12 point socket to remove the pick up. Just remove the pump and pick up together. JT
Since you posted in the READ ONLY Classifieds I am starting this post for an FYI not only for this request but any other that may be similar.
  If you wind up having to pull the pan and pick-up yourself - be prepared.  One of the two bolts has obstructions that get in the way - even with a swivel socket.  Also, most I've seen use a  star type bolt. It's been a while and I can't recall if it is internal or external.  Maybe someone with more recent experience can alert you.
You would hate to go to all the trouble to pull the pan only to find that issue hanging you up.
Tom
