  • Online today: 295
  • Guests: 198
  • Total: 198
Steering knuckle - need to change
Started by Reeves1, January 04, 2013, 08:53:19 AM
I still have the flex shaft.
Reason I wanted the U-Joint was for more clutch cable clearance, by/at the rag joint.
I have the Quick Time bell.
I came up with another idea for motor mounts. They will be a semi solid type, so more cable clearance may not be required now. I'll see after the new mounts are made.
72pair
Does your car still have the original column with flex shaft? I'm thinking you need to swap in a later column with a solid shaft, then you can add in u-joints starting near the firewall and route around whatever you need.
Got it. But I didn't take into account the length.
The distance between the rack & steering rod is too close for it to fit. I do not think I have ever had a steering column out, so have no idea if it will collapse/push in enough for the U-joint to fit ?
Anyone done this ?
Called Mopac. They didn't have it.
Edit
Just tried the Flaming River site again. Worked this time.
OhSix9
call mopac in edmonton. they should be able to gt what u need
Virgil to Sid
Flaming River didn't work. To order you have to "join" that site & it will not let me. Tried at least 10 times to order & it will not work. They made it very hard to order parts.
Due to what I'm working & in a no cell service area, I cannot call them during the day.
This looks like what I need. Ordering two & will up-date this topic when I test them.
http://www.flamingriver.com/index.php/products/c0005/s0003/FR2631
Racer - the 3/4" end of that one is a double D. See my pictures above. I found lots of those up here. Did you mod the steering end to make them fit ?
Sedan - Thanks - I'll call them next time I am off work early.
racer99
We always use a 9/16 for the manual rack end,Reeve.
This one has the most clearance,
http://www.jegs.com/i/JEGS-Performance-Products/555/60732/10002/-1
sedandelivery
Just for the heck of it, call flaming river to see if they can help. They deal in Pinto/Mustang II steering normally for Hot Rods.
Still have not found one. Working away from home 24 on 4 off makes it hard to get stuff done !
Found this on Speedway & sent them an e-mail.
Item #:
10630307
Item Details:
Pinto/Mustang II Manual
http://www.speedwaymotors.com/AFCO-U-Joint-9-16-Inch-26-Spline,41052.html
Up-date.
Sent pictures to the go to sped shop up here (Mopac in Edmonton) & they couldn't find one.
New pics below.
Rack shaft is 9/16" x 26 spline.
Steering shaft is 3/4" wide & single D.
Over the next days I'll try & find at the places mentioned.
In the mean time, if anyoe finds one please let me know. Limit on my time when away working.
After using the chart go to Flaming River and check what they have or try Speedway.....
289Wagon
 Spline count
289Wagon
289Wagon
 You will need the OD  and spline count on the rack end. It looks like you have a manual rack, so it should be 9/16 -26. The power rack is 3/4-36.
The shaft should be a 3/4 inch double d. AKA - DD     On mine the 'flat' is .581 and the round is .746
I have some charts for those type of joints, but I still can't figure how to post an image on here. Also, Moog has a detailed chart for coil springs. I'll try to PM you a link to that.
Knew "rag joint".
What I need is the steel type u-joint. They are smaller around & will give me more clearance for the clutch cable into the Quick Time bell housing.
Thanks though !
Here U go !   Fred   :)
pintoman
It's called a rag joint.You can get replacements at your local auto parts store.
Need the U-joint type knuckle. Don't know what they are called ?
Place to get them ?
It's on my 72 & I need a bit more clearance for my clutch cable.
Someone have the righ part number as well ?
Maker ?
Thanks
Derrick
Duh !
http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Nickel-Plated-Steering-U-Joints/1513380/10002/-1
Anyone know the right part number ?
I'll measure my shafts later today.
