v8 springs
Date: 05/07/2017 04:46 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
72 pinto drag car
Date: 07/08/2017 08:53 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 10/11/2019 11:13 am
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 09/01/2017 11:58 am
  • Online today: 529
  • Guests: 449
  • Total: 449
What is this?
Started by From_Jonah, January 03, 2013, 10:02:04 PM
Quote from: 78txpony on January 06, 2013, 10:20:44 PM
Is that 17mpg in the city or on the highway?  I can get about 21 in the city with a stock 157k mile 2.3 with the emissions crap on it.  One thing that killed the mileage a lot in cold weather was an overly rich choke (pulloff needed to be tweaked open more than the service manual instructs), and the EGR temperature switch that activated EGR when it was too cold.
Therefore you might want to check everything else before pulling parts off.  Since yours only has 60k on it, has the timing belt and valve seals been changed?
If you procede with the emissions strippage, please post a progress thread, as I might be interested in doing this, too it is really helps it.
My AIR pump, cat & all the vacuum lines were removed before I bought it. It sat in the corner of a bodyshop almost 15 years before I got it. It had a new timing belt but was off by almost 30 degrees & the distributor was advanced so far I'm amazed it ran to get it home. I got the timing dead-on & installed a new water pump, hoses, thermostat, radiator & belts while I was under the hood. I also changed the oil & filter which looked clean considering it probably hadn't been changed in the 15 years that it sat.
This engine fires right up without a hint of oil smoke & idles as smooth as any new car I've ever had. It holds almost 50 psi oil pressure hot & rarely goes above 170 degree temps even in 80 degree weather thanks to the new parts. It gets 17 mpg highway & falls to 14 around town. It's an auto trans car with 3.00 rear but this mileage stinks even for anautomatic wagon.
All the vacuum lines that send signals to the stock carb are capped & only a single vacuum line goes to the distributor now. I'm sure the ignition box has pre-set curves based on emissions for '76 & with all the sending units no longer getting vacuum or sending the correct electrical impulses where they need to go I doubt the engines running optimally at cruising speeds. I suspect it goes from rich to lean constantly as I drive though the plugs read perfect when I checked their color.
In '74 only California cars got AIR pumps but all Pintos had cats. The ignition should have a very simple advance curve based on RPM & swapping to it should eliminate emissions calibrations. I picked up an NOS water choke '73 2.0 carb that's pre emissions so that should eliminate the vacuum headaches of the stock carb. Everything I can find says it has the same CFM rating as the stock 2.3 carb & it's physically identical other than having a lot less vacuum ports. I can't wait to swap these parts on in the spring & finally get this car up to it's potential.
78txpony
Quote from: Pinto5.0 on January 06, 2013, 03:00:43 PM
  My 60K mile '76 wagon is missing the cat & the AIR pump is gone & all the vacuum lines are history but it still has the stock carb, distributor & electronic box. I got it this way & set the timing at the belt & distributor(they were both way off) & spray cleaned the carb & it runs great & idles smooth but I only get 17 mpg out of it.
-Rob Young
1997 H-D Sportster
Quote from: Ricpinto on January 05, 2013, 12:16:21 PM
Because the A.I.R (smog pump) does nothing until combustion has already taken place, IMHO it has very little (if any) affect on engine performance
By itself, no. It works in conjunction with the distributor curve, advance controlled by the Duraspark box & all those vacuum lines & sensors that modify the vacuum advance to change timing under load as well as change air/fuel ratios in the carb.
My solution has always been to eliminate EVERYTHING at once including the cat to avoid any issues. My 60K mile '76 wagon is missing the cat & the AIR pump is gone & all the vacuum lines are history but it still has the stock carb, distributor & electronic box. I got it this way & set the timing at the belt & distributor(they were both way off) & spray cleaned the carb & it runs great & idles smooth but I only get 17 mpg out of it. I figure this is due to the stock emissions carb & ignition system getting & giving false signals at cruising rpm at highway speeds.
I bought an NOS '73 carb for a 2.0, a new '74 2.3L distributor & will get a '74 spark box & put it all on in the spring. I expect  my fuel mileage to jump to 23-26 mpg once it's running all pre-emission parts.
289Wagon
cutelitlputtputt
Ok.  I figured you have to prep or do other things when you remove the stupid smog system.  Unfortunately you just can't rip it out!!!   Weeeeee!!!  I would love to do that!!!
Anything to keep her runnin'!
From_Jonah
Okay. I believe the cat to be original so I'll either remove it or replace it. Depending on what I do with the smog pump.
RSM
The smog pump is designed to add air to the exhaust to help with emissions. If you take that away,(and if conditions are right) it could possible lead to a cat failure which in turn could restrict exhaust flow causing the fuel mileage to get crappy etc etc etc. If you don't have emissions in your state and your going to remove the smog pump also remove the cat.
From_Jonah
Could it possibly hurt performance?
D.R.Ball
Do not be so sure that the engine will run better with out the smog equipment..
DBSS1234
If you want or need to maintain the stock appearance without the drag on the engine take the pump apart and remove the thin plastic vanes that "pump" the air. The unit looks correct but with out the vanes there is no resistance on the engine.
cutelitlputtputt
You guys are rubbing this in!!!!  The smog pump, probably many of those vacuum lines....can go
Your car will run better and get better gas mileage!!!  Ohhhh, I'm getting sick...
From_Jonah
Oookay! I thought that could possibly be what it was but wasn't sure. I'm in Alabama so it can go  ;D
Quote from: cutelitlputtputt on January 03, 2013, 10:31:35 PM
I know, I know what this is!!!
It is a smog pump!!!!  Mine was loose and making a funny noise!!!
I wish we did not need these stupid things....
Hehehe.. How I love living in Ohio where we do not need those stupid things...  ;D
cutelitlputtputt
From_Jonah
What is this mystery thing and what does it do? The belt is very worn out but I'm not even sure what it does.
