SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 11/29/2018 10:26 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 07/30/2018 04:32 pm
  • Online today: 642
  • Guests: 584
  • Total: 584
Turbo camshaft specs
Started by Pinto5.0, December 18, 2012, 06:26:50 PM
I got my roller  (early 90's Mustang) at Pick A Part for under $20 out the door at their 50% off sale. That price included the roller rockers which I both strung on a wire and also scratch their respective number to make sure they got back on the right lobe. As best I recall the 50% off price was $12 for the Cam and $.75 each for the rockers.
Tom
Quote from: Bigtimmay on December 19, 2012, 12:12:25 PM
The later turbo cams 85.5-89 had .400 lift the earlier ones so Id say that includes 79-85 not just 83-85 had .390 lift Id just run it as long as the followers arent wore out or anything like that and when you get to that later stage look into Boport cams some of the best cams youll ever find for 2.3turbo engines!
My cam & followers is like new. I just want to use it until I upgrade down the road. I'm planning on a roller but that's not until I decide how much power I wanna pump out. I'm trying to keep the daily driver aspect & get 25+ mpg out if it so I may not go any farther with this car.
One aspect of a roller cam that might apply to the Ranger (or Mustang) cam is ramp speed.  A flat and roller cam may have identical duration, but the rate at which it rises in a roller can potentially be faster. To put it another way if measured at a quarter of the duration (half way to maximum lift) the lift has a greater potential to be higher in a roller cam (if so designed). In the Ranger (Mustang) cam that may not be the case, but the potential is there.  This may be one reason why the lift is lower yet the power potential is equal or greater than the flat cam.
The factors are there, but I have not measured the roller in degree increments to know if this is, or isn't the case.  Has anyone here ever done it?
Tom
Quote from: Pinto5.0 on December 19, 2012, 07:20:05 AM
Everything I see online shows the Ranger roller having .355 lift compared to the Turbo Coupe slider with .411 lift which is a sizable downgrade though performance is similar.
I have the nearly new '79 turbo slider that I'd like to use until I'm ready to jump to the big VAM, larger injectors, bigger turbo & at least the .420 roller cam in the future.
I would swear that the '79 specs said it was around a .400 lift cam. I do know it had more lift than NA cams in '79
racer99
Engle 55 or 111 works for off the shelf.
The A237 sounds nasty in my 2.3T
It isnt optimum but it came in the engine
when I got it.
i dont recall but its a slider cam and is a very reserved profile.... with the absence of zinc in new oils its probably a good idea to look for a roller cam.....the later turbo cams were .400 lift..... many go to a ranger roller cam as they dont wear out.... they are 390 lift....the ford motorsport roller cam( a 237 ) is 420 lift...if you want to spend a little to get a good cam  both schneider and engle both have 2.3 turbo grinds on a roller cam... im using a engle hot pinto roller ... they have a small and a large version... im running the large.....it does have a lot of lope at idle...
Does anyone know the lift & duration of the stock cam in the '79-'82 draw thru turbo engines?
