Date: 02/27/2017 10:10 pm
Date: 03/25/2019 09:02 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 07/13/2018 02:21 pm
Date: 07/08/2022 11:51 pm
Date: 12/31/2017 09:03 pm
nos core support
Date: 01/03/2020 09:39 pm
Date: 07/10/2016 10:17 am
77 pinto
Date: 08/22/2017 06:31 pm
  • Online today: 600
  • Guests: 435
  • Total: 435
1980 gas tamks
Started by sedandelivery, December 09, 2012, 05:56:12 AM
allendeloura
You will also be able to get the screw out with a 9/64 size allen wrench.  Just secure the allen wrench in a pair of vice-grips to get the stability and leverage for removing the bolts.  Just did this today.
HOSS429
should be torx type screws and no they have no nut on the back side .. they just are very tight .. dont worry about breaking one .. they only screw into sheet metal ..
sedandelivery
The screws on the filler that have to come off, they are allen wrenches. Are there nuts on the back, or self tapping. I am asking because on an old Pinto I tried to loosen them and they were frozen fast. I need info before I try to work on my car. (it runs so well!)
onefarmer
If your tank is leaking due to rust, find a radiator that cleans and seals gas tanks. They clean them out and plastic baked on coat them.
HOSS429
it`s not the least bit difficult to pull the tank  ;).. pull it and see .. my 80 tank was rusted at the top .. would only leak when full as you say ..but it was too rusty to save anyway ...
289Wagon
 Have you checked the vent valve rubber grommet ? It's located on the top of the tank to the right of the filler tube.
79prostreet
Sedan,  when I pulled the tank out of my wagon I noticed that the fill tube had a rubber gasket that sealed it as it went in the tank, any chance that could be your source of leak since it does it at full tank? Might be that rubber has dried out / cracked and does not seal any more, might be worth checking. Bud
79prostreet
sedandelivery
That probably says it all. My tank leaks when filled to the top and I can have a free hatchback tank, but now I know it won't fit. Thanks!
289Wagon
 All I can say for sure is they have different part numbers & capacity.
sedandelivery
Are the wagon and hatchback gas tanks the same for 1980's?  Thanks for the help!
