77 pinto
Date: 08/22/2017 06:31 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Oil pan front sump style
Date: 01/10/2017 09:19 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 02/04/2018 08:26 am
Date: 02/22/2017 01:58 pm
Date: 12/31/2017 09:03 pm
  • Online today: 489
Quick Disconnect Nitrous Bottle Mount
Started by entropy, December 08, 2012, 06:57:04 PM
entropy
Aaaaaand the project is stalled. One of the aluminum roller rockers in the 289 broke completely in half at the trunnion.  Fortunately, the pushrod didn't bend, the break is clean with no missing material and the bearings are intact, so no needles went through the oil pump or anywhere ense. So, slight pause while I replace the set...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
cabecho
Aerodynamics is for those who can't build engines
If ford pintos are not fast then why chevy's have to use there parts to make them fast?
cabecho
i seen a few ways people mount them on there rollcage.
this specific picture is for a smaller bottle but i know they make them for 10lb bottles.
i will look up tomorrow the part number and posted.
79prostreet
Sounds like you've thought it thru, now make it happen!
79prostreet
entropy
So I'm putting a blue bottle (10 lb) in the back of my '72 V8 hatch and there are too many things in the way...mainly the gas tank and rollcage to put it where I had initially planned, so I'm looking at alternatives.  The clever one (I think, anyway...) that I've come up with is this: a removable platform which attaches to the rollcage.  I've got two bars in the "cargo"area which run across the body and which are 25" center to center, and the aluminum plate platform would attach to the rollcage bars with 4 of these clamps:
http://www.theatrehouse.com/product/8379.html
the clamps have a combined capacity of 220 lbs which should easily handle any loads that bottle could possible see. The means the entire setup...bottle, mounts and all, can be removed in seconds with no tell-tale holes left behind. So....what do you think?  Will it work or is it just a terrible idea?
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
