Date: 12/15/2018 02:21 am
Date: 02/25/2017 08:45 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Date: 04/24/2018 11:45 am
Date: 04/15/2017 05:14 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 09/21/2018 11:35 am
  • Online today: 587
  • Guests: 216
  • Total: 216
Verify facts about T5 Transmission conversion.
Started by earthwizard, December 06, 2012, 05:08:15 PM
earthwizard
Hello. I want to install a T-5 trans into my 2.3L 1973 Pinto sation wagon. I have read everything I can. I still have some questions if you could help me out that would be cool. I'm looking for WC T-5 trans with the bell crank type of bellhousing, if I'm not mistaken. I found A 1987 T-Bird turbo trans, complete from flywheel to shifter.
Q. Is the 1985-1986 Thunderbird 2.3 Turbo trans a better set up than the 1987 2.3 Turbo, for this mod?
     a. Are they the same? Besides the gear ratio's?
Q. To use a cable type clutch vs hydraulic. What is going to be the best bell housing to use?
     a. The Original one from the 1987 T-Bird?
     b. A D5 or D9 has been mentioned?
Q. What mods will need to be done to the crossmember with my future set up?
     a. Flip the crossmember 180*?
     b. Notch the crossmember?
     c. Build a custom bracket off the bellhousing to accommodate cable hookup?
Q.  If I was to use a D5 or D9 bellhousing can I still use the T-Bird factory clutch?
Q. Will I need to modify my bellhousing, when using the 2.3L engine?
Q. Is a T-5 Thunderbird 2.3L Turbo trans better than a non turbo trans?
Q. Will I need to use a different trans mount?
Q. Will I need to notch the trans mount?
Q. Will the stock shifter from the T-Bird need mods?
Q. Does any of these mods with the Flywheel/clutch assembly effect the starter motor?
I'm sure I have more questions. Let's see how this works out first. Thanks' for any and all help!
Reply
Quote
