Wheels and Parts
Date: 07/06/2018 04:50 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 08/30/2021 03:20 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
free transmissions
Date: 11/28/2019 10:21 am
Date: 02/28/2018 09:37 am
1976 Pinto
Date: 10/24/2017 02:00 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
  • Online today: 548
  • Guests: 500
  • Total: 500
has anyone moved the front seats back?
Started by Clydesdale80, November 28, 2012, 10:08:29 PM
Clydesdale80
thanks for the reply but I am planning on keeping the backseat for now and using the original front seat.  I probably will just end up doing trial and error moving stuff around, I just thought someone might have done it and known how far back you could go and what worked well.
Bought a 1978 hatchback to be my first car.
I moved my race seat back from stock position a bit and much closer to the trans tunnel for better weight distribution. I'm only 5'10" and have no back seat room to consider either. I placed the seat in a mocked up position and sat in it until it worked with the steering wheel and peddles then marked and welded new brackets to the floor pan. I put washers in steering wheel mount to correctly re-center the wheel to the new seat position but you won't need to do that in your case.
Clydesdale80
I'm gonna be welding in a new floor and adding subframe connectors pretty soon, I think this would be a good time to move the seat mounts back a couple inches. Have any of you done this? how far back did you move them?  Any suggestions would be great.
I'm only 6'2'' but it is still fairly awkward to get into the driver's seat.  My main problem is getting my leg between the steering wheel and the seat so I thought an extra couple inches would make the maneuver more comfortable.
