Date: 07/01/2019 03:17 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 07/01/2019 12:23 pm
Date: 08/02/2019 04:18 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 12/04/2018 07:40 pm
Date: 07/04/2022 07:55 pm
78 windshield trim
Date: 02/01/2020 08:46 am
  • Online today: 548
  • Guests: 286
  • Total: 286
Help!!
Started by ccrain, November 20, 2012, 05:05:44 PM
johnbigman2011
Don't let an old camper stand in the way of building a Pinto!!!
ccrain
Guys i have gotten side tracked from working on pinto.  In my way of moving the pinto is a old 60s camper that has a tire that will not hold air.  When the tires are flat the leaf springs are on the ground so its impossible to move, it strained are ford 4000 tractor trying to pull it.  So I bought a bottle jack yesterday (6 ton) , so i plan on putting another tire/ rim on it and moving it.
johnbigman2011
Told you... Fred knows them Pintos, inside and out!
Pull steering wheel off remove block next to lock pin with phillips screw driver add a small hardware nut on top of pin replace lock block install wheel you are now ready to rock !    Fred   ;D
cabecho
you could use a drill and a half inch drill bit. that will do the job.  ;D
dont get mad i was just kidding.
Aerodynamics is for those who can't build engines
If ford pintos are not fast then why chevy's have to use there parts to make them fast?
johnbigman2011
Are you stealing it!!! :o
Nah..... Ask Fred Morgan, he could give you some advice on that problem.. I'm sure
ccrain
Tommrow I am going to pull the pinto to my workshop but I have not keys and the steering wheel is locked.
