Date: 08/22/2018 09:23 am
Date: 12/30/2022 01:30 pm
Radiator
Date: 05/27/2018 06:07 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Racing seats
Date: 10/24/2019 09:41 pm
Date: 08/01/2018 01:17 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 07/08/2022 11:51 pm
  • Online today: 536
  • Guests: 481
  • Total: 481
removing a rear axle
Started by alyle123, November 19, 2012, 05:31:18 PM
Then use a big freaking slide hammer bolted to the studs and slide the slide hammer back and forth until loose. Make sure that the slide hammer flange is bolted on the wheel studs tight or you can strip the studs....Pretty easy...
6.7 is most common. Remove brake shoes. Using 9/16" wrench loosen the 4 bolts holding bearing retainer cap on.   Fred   :)
alyle123
Have never torn into a rear-end before but thought taking a rear axle out of a Pinto rear end would be rather simple.  Haven't cracked the code yet!  I'm looking for a video or step by step photo guidance.  It's probably something simple but I can't find it.  Any help available?
