72 pinto
Date: 06/23/2016 12:40 pm
72 pinto
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 09/05/2018 06:30 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 10/24/2019 01:45 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 03/13/2021 12:57 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
  • Online today: 314
  • Guests: 332
  • Total: 332
2.0 Mounting Issues
Started by James Meter, November 18, 2012, 09:20:41 PM
James Meter
I'm in South East Missouri. 40 mins south of St. Louis just off of Hwy 67
Bought my Pinto in '12, last tagged in '97. Had it on the road (thanks to a $20) spring '14. Tima to tear it apart, fix it correctly this time....and play with the drive train. Got a totally free & complete drive train-engine, 5 speed, drive shaft, and computer!
cabecho
where are you at? i may take you up on that 2.0
Aerodynamics is for those who can't build engines
If ford pintos are not fast then why chevy's have to use there parts to make them fast?
Quote from: fast64ranchero on November 20, 2012, 10:07:09 AM
JMO, Don't waste your time putting the 2.0L in the car, you'll have to change the frame mounts, and exh. plus it's getting real hard to get parts for the 2.0,  Find a 2.3 Lima and put in it...
Funny, I was thinking this when I 1st read his post. I just didn't know a smooth way to put it in words.
James Meter
Thanks fellas, and anyone looking for a 2.0....just lemme know! Asking $125 OBO
I have done a 1.6 trans to a 2.3 there is enough mount bolts to have good alignment. My opinion is forget the 2.0 parts are hard to find and very costly. 2.3 they made for so many years that parts are plentiful .   Fred   :)
HOSS429
what he said .. there`s millions of 2.3s out there ..
fast64ranchero
72 old V-8 parts Pinto
73 pinto, the nice one...
jeremysdad
I can't help with the mounting issue for the engine, but I do know from  researching putting a 5spd behind the 2.0 that the belllhousing bolt patterns for a 2.0 and 2.3 are the same, but the dowel pins are in slightly different locations, iirc. There is a guy floating around somewhere that makes stepped dowels that'll make it work, but you'll have to  search here to find it, cause apparently I forgot to bookmark that particular thread.
Good luck! And happy Thanksgiving! :) lol
James Meter
A cracked 2.3 is what the '75 Frog originally came with, but I got a '71-'73 German 2.0 for $175 [and it's tranny, and a drive shaft outta a derby car.] I felt really good about a swap..untill I started looking at the engines side-by-side.. >:(
Imma have to some how have to either move the mounts on the frame backwards around 6 1/2"...or make some new mounts so it'll mate correctly with the German 2.0. Does anyone have any experience with these issues?
*Have not taken the 2.3 out of the Pinto yet*
Also: Do they both use the same type of auto transmission? (The 2.0 &2.3) The bolt pattern looks similar.
