upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 02/26/2017 03:22 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 08/16/2018 08:54 am
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 10/14/2019 08:24 pm
  • Online today: 584
  • Guests: 387
  • Total: 387
Clutch Pedal Assy Swap
Started by lugnut, November 05, 2012, 08:51:44 PM
derekrichmond15@yahoo.com
I will be doing this in a few days to a 77 pinto& 80 bobcat I will be taking clutch & brake petals out of bobcat & place them in pinto for my t56 yes a 6 speed pinto bobcat will have a c6& a stock 351w pinto is getting a 351w turned into a 408w stroked will my pedal swop work ?
1977 408W stroked pinto
When I inquired about the conversion on my '73 I was told that there were four different pedal configurations used on the Pinto. Obviously the '71-'73 (and apparently some '74's also). I'm not sure how the others were split years wise, but I was told that brake booster models required a different pedal.
So, sorry I don't have a definitive answer, but I'd recommend caution to the things I mentioned.
Tom
cromcru
anything before oct 74 after that 75 model year comes in. my car was build on april 1st lol
cutelitlputtputt
Quote from: lugnut on November 05, 2012, 08:51:44 PM
I eventually want to change my 1974 2.3 Wagon from automatic to manual transmission. Will the clutch/brake pedal assembly from my 1977 parts car fit? Both cars have manual brakes.
TIA,
Mike, (I like Lugnut!)
The clutch pedal assembly from your '77 may not work on your earlier model car.  However, I do have a late model steering column channel that would make things work on the '74 for $32 plus ship.
Jennifer
Anything to keep her runnin'!
opietrials
When you say early year '74, what date am I looking for?  I am about to purchase a '74 automatic car that I would like to convert to manual, but I don't want to buy a pedal assembly from the wrong year car.  Thanks!
1974 Pinto Sedan
cromcru
if your clutch holes are there for the later pedal assembly then it will work.if you have an early year 74 then you will have to use the early pedal assembly from 71 to 74 like i have to do,or use later model steering bracket and everything else that goes with that. aka  damned if you do and damn if you dont. ill be putting my t5 in this week, since i have been laid off work and the company closed its doors.i hope that helps
I plan to do that exact swap myself between the same years. It's supposed to be a bolt in job.
lugnut
TIA,
