74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 08/01/2023 06:53 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 10/10/2019 10:02 pm
Date: 10/28/2018 08:45 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Built 2.0
Date: 10/07/2018 05:27 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
  • Online today: 210
  • Guests: 149
  • Total: 149
Need help with a 2.0 carb...
Started by vanerock, October 25, 2012, 08:34:39 PM
vanerock
Gotcha, I think I can figure something out after looking at it, when I called racer walsh they told me they no longer offer that item, but I think I can make something work, thank you for the advice
72pair
I used an '87 or so mustang 2.3 FI throttle cable and made an angle bracket off the carb stud to hold it. That cable has a built in return spring and bolts to the firewall like the stocker. It also has enough length for the sideways mount of the carb. I have one of the Offy linkage kits, but didn't use it...my method was simpler.
If attachments work, they show three different part numbers (01103, 1241, and 8505) for Racer Walsh 4 barrel carb throttle adapters.  These numbers no longer show up on their web site.  If truly no longer available, maybe you could fabricate a bracket based on the #1241 photo.  Have fun.
vanerock
I'm trying to put a holley 390cfm with the offenhauser manifold on my '72 2.0, The problem I have run into is how to mate the factory throttle linkage with the holley carb. Racer Walsh sold a kit years ago for the linkage but if they still make it, it isn't listed online. I am planning on calling them my next day off, but i figured I'd ask and see if anyone else dealt with the same problem and knows an easy way to make it work, or even if anyone knows about somewhere to buy the linkage kit.
