Date: 12/09/2018 11:35 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 10/03/2018 10:46 pm
Date: 02/05/2017 09:45 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 03/15/2023 02:16 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 11/11/2019 04:49 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
  • Online today: 481
  • Guests: 259
  • Total: 259
Timing Cover Question
Started by 80_2.3_ESS, October 18, 2012, 10:47:05 AM
I like to cut cover in half just above timing indicator so I can always see cog belt condition.   Fred    :)
When I get to installing mine, I will cut a circular hole where the adjustable gear is at.  I have seen it done by others and think the look is pretty clean.
yep... got one with a hole cut out of the top and one with the top half cut off.....
80_2.3_ESS
Gathering the last of the parts for my 2.5L motor that I am building for my Pinto. One of the items I am adding is the round-tooth conversion kit for the timing belt, and adding an adjustable cam-gear.
For those of you who run the adjustable cam gear, what do you run for a cover? Do you adjust it with the cover off, set it, and then cover it? Did you cut-away the top portion of a factory cover to adjust with the cover on? Maybe bore a hole in the cover to access the gear with it on, while covering the belt itself?
Was thinking it would be cool to run a clear-plastic cover to show off the nicer gears and all, but don't think I've ever seen / heard of one before.
Any input would be much appreciated.
Nick in CT
1980 2.3L Pinto ESS
