Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 03/06/2019 06:40 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 02/18/2017 04:44 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 08/09/2018 07:49 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
  • Online today: 553
  • Guests: 244
  • Total: 244
A4LD ??
Started by Pup70, October 16, 2012, 09:16:13 AM
Second on the Merkur XR4ti having the C-3. Try 1987-1988 Ford Thunderbird Mustang, Ranger etc..... Simple way to check is check the shifter if it says O.D.on the gear selector that's what it is.....If not it's not an A4LD.
As far as I know XR4TI's came with C3's  I do not think the A4LD came in them.
fast64ranchero
You can change the bellhousing on the A4LD, you'll need to find a bell from a 2.3 or 2.5 Lima engine, the tranny can be from any engine as far as I know, stick with a early one, 80's to early 90's, not sure what years had gear selectors for 1,2,drive and overdrive and what years had OD activated by 12Volts, you can also apply lockup using a 12volt toggle.   Look for Turbo coupes, XR4TI's, 4 and 6 cylinder mustangs, rangers, and bronco's.
you'll also need to modify the tranny mount, early 2.3 pinto flex plate should work, and lastly the A4LD yoke will be needed.
72 old V-8 parts Pinto
73 pinto, the nice one...
78_starsky
here is a bit of info on the transmission.  to get one i suggest going to a pick a part auto wreckers and get one from a bronco or ranger.
http://www.therangerstation.com/tech_library/a4ld.html
do these bolt up or will you need to find a different bell housing?
Pup70
Dose any one know where I can get my hands on  A4LD trans. I want to put it in my 77 cruiser wagon I drive on the highway and an overdrive would be nice. It didn't have to be built just something I can start with
