Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 09/21/2018 11:35 am
Date: 01/24/2017 12:36 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 05/28/2017 03:20 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 04/14/2023 06:15 am
  • Online today: 2,612
  • Guests: 2575
  • Total: 2575
New turbo project started
Started by fast64ranchero, October 04, 2012, 07:25:15 PM
fast64ranchero
As soon as I recover ($$$) from the EFI tranny and rearend, I'll get to work on the turbo setup.
72 old V-8 parts Pinto
73 pinto, the nice one...
johnbigman2011
One thing for sure... You shouldn't or you might get a ticket from the shiny police 8) Does look good!!
johnbigman2011
Now that's is a thing of beauty, for sure.. I think I see room, for a nice turbo with a custom header in there as well. 8)
fast64ranchero
Well it's up and running with the EFI setup, I still have to add another vacuum port in the intake for the valve cover breather and make a better Cold air intake setup.
Next will be installing the A4LD, custom convertor and 8.8 rear, have yet desider if I am going to run the 3.73's that are in the 8.8 or install the 4.56's I have. the 4.56's would wake up the bottom end and still run down the highway at the same rpm as it does right now with the C-4
fast64ranchero
Almost finished
On the car, now the fun begins, wiring.....
fast64ranchero
Made some progress,
Tomorrow I'll angle cut the velocity stacks to 20 degrees to match the head, and make them all equal in length, more to come.
Getting closer, next I'll cut down the plate and the get the plenum welded on...
sedandelivery
Very nice job on the engine compartment! Outasite as they used to say...or was it groovy?
mrskydog
Very impressive ...wow..Nice clean job!! :P
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
bbobcat75
man that engine bay is CLEAN!!!
go luck with the build!!
1975 mercury bobcat 2.8 auto
johnbigman2011
One thing for sure. When Walt puts his mind to it hang on!!! Looking forward to following this build for sure.
fast64ranchero
I'm not your normal guy, I just don't/can't leave stuff alone, a while back I built a nice little 2.0L for my 72, it turned out great, runs good and looks killer...
but good enough, sometimes isn't enough...  here's a picture of my future intake, I already bent the alum for the plenum, the tubing (1.75 od 1.5 id) and will be 4 velocity stacks tomorrow, the flange was cut off a stock intake and machined flat, and the alum plate 3/8"x 4" wide, will end up being the bottom of the plenum
the next picture, is a box of schedule 10 304 stainless steel tubing, elbows, all 1.55" ID and 4"x3/8" for the head flange, I already made the merge collector, I bought a T25 flange and gasket off ebay,
It'll all be controlled by Electromotive Tec GT setup just like my 71 turbo car...  I have a nice used set of 5.5" Crower billet rods and Vonolia pistons I'm going to use if I can find a block that will bore 0.020 over...
The pressure will be handled by a EFR 6258 turbo, (I think, I haven't purchased it yet) this will be a true street car, with small runners, small turbo, a A4LD tranny (Overdrive) and 3.73 gears.....
