Sunroof shade
Date: 06/19/2019 01:33 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 10/10/2019 10:02 pm
Date: 11/29/2018 10:26 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 04/10/2017 07:30 pm
  • Online today: 210
  • Guests: 183
  • Total: 183
bobcat villager
Started by wondersmelonade, September 12, 2012, 08:24:00 PM
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
wondersmelonade
dianne
Quote from: wondersmelonade on October 31, 2013, 04:17:28 PM
Oh yeah  ;D
Doing mine in grabber blue with the black grabber accents :)
Like this:
Gotta find the spoiler though...
Vehicles:
wondersmelonade
wondersmelonade
Honestly, I'm A BIt Of An Oddball. I Like The MII Best Minus The Taillights. If I Ever Own One I Would Do The Small Pinto TailLights Or Maverick Ones. A Maverick Is My All Time Goal. I Like Things That Are Not Common. If I See A Camaro Chevrolet Or First Gen Mustang, It Hardly Even Peaks My Interest.
dianne
Quote from: wondersmelonade on October 31, 2013, 12:48:26 PM
No No. It's Not Mine. It's My Neighbors. I Like MII's And Fox Bodies A Lot Though. Neighbor Has A 73 Mach 1 As Well
Well, you need one now ;)  I'm not fond of the 71 to 73 - too big and not a muscle car look at all. I had a 70 Boss, that's my favorite year followed by 69 and then the IIs. The new ones look like an old man with money should be driving them LOL
Vehicles:
wondersmelonade
dianne
That's the Fox body I think! Cool :D I have the last year of the II and you have the first year of the fox :D
Vehicles:
wondersmelonade
dianne
Quote from: wondersmelonade on October 31, 2013, 11:53:14 AM
Thank You! Will Post A Walk Around Video On YouTube When I Can Get It Outside. Have A Mustang In My Way Lol
What kind of Mustang? I just picked up a 1978 Mustang King Cobra II
Vehicles:
wondersmelonade
dianne
Vehicles:
wondersmelonade
Well, It's Been A Long Time Since My Last Update But I've Certainly Been Busy. The Car IS Painted, Reassembled And Running. If Anyone Would Like To See It On YouTube, My Username Is Wondersmelonade.
I Ended Up Using A C4 Trans Out Of A 68 CougaR, Which Is Where The Engine I Am Now Using Came From Too. THe Original 302 I Bought For The Car Had 2 Spun Bearings And 4 Cracked Pistons. Yeah... I Got Ripped off.
wondersmelonade
So the engine is actually a 68 with j code heads and a mII oil pan and pickup . Ground out the thermactor bumps and very very lightly work the exhaust side. Also installed new valves and seals.put in new oil pump, summit cam and lifters and a billet double roller. Set timing straight up. Got a mII flexplate(autozone special order,) a mII bellhousing, new water pump, and serpentine accessory set up from 87 lincoln. Also went with a carter afb 500 cfm carb and performer rpm intake.
Should work out well
Thinking about builing a tie bar with heim joints and tie it to the firewall. Anyone ever seen one on a Pinto/Bobcat or have advice?
wondersmelonade
Picked up a 302 out of a 78 KC with motor mounts, all the accessories, Lunatti cam, Edelbrock 4bbl intake, etc. Just need a small bellhousing and eventually a c4. Might try and fit my c3 to the mII bell once i get one. I figure the c3 will hold with my style of driving.? I think the motor mounts from the Cobra might work with my V6 mounts. Not sure.
I knew you were kidding  ;D  I usually over-explain to help out the people who will scour these forums in the future. Most of my searches yield half an answer & pics are always missing. i'm just trying to be thorough.
wondersmelonade
That was me being passive-aggressive and suggesting that you sell them. Was just messing around. I appreciate the help a lot and youre absolutely right on about them hitting the spindle. I will try to find someone local but may have to email youre photo to the link i posted above
Quote from: wondersmelonade on December 02, 2012, 04:18:27 PM
That front end looks great!  I believe you want to sell me those brake hoses!  ;D
Just trying to save you some headaches. I spent a week trying to make 3 different aets of hoses work before I went to Kenny's with the spindle assembly & test fit these & the hoses cleared the channel machined in the spindle. That's the 2nd problem with dropped spindles. Besides the hose now being too short the crimped end that threads into the caliper hits the spindle & there is no simple fix for that other than this type of line. I refused to grind my new spindles.
wondersmelonade
Here's a couple pics of what I used. I slit a length of fuel hose & ziptied it over the lines because the added length gives you a few potential rub points but that's extra insurance they will last the life of the car.
wondersmelonade
I have a local street rod shop called Kenny's Rod & Custom so I got mine there. I've seen them on Ebay cheaper but I needed then that day. They can be had with fittings for either the stock Pinto calipers like I got or the fittings for GM Metric calipers if you went to big brakes.
wondersmelonade
Where did u get yours from if u dont mind?
For front brake lines with my dropped spindles I used 20" braided lines for street rods with straight ends instead of the banjo. Cost 50 bucks for the pair with all fittings.
wondersmelonade
http://www.facebook.com/photo.php?fbid=10152312616870174&set=pb.567395173.-2207520000.1354334638&type=3&theater
Removed bumper horns
http://www.facebook.com/photo.php?fbid=10152312616320174&set=pb.567395173.-2207520000.1354334638&type=3&theater
Put mount in cold saw and cut outer shock sleeve completely around. Also cut a small slit to allow foamy stuff out.
http://www.facebook.com/photo.php?fbid=10152312616305174&set=pb.567395173.-2207520000.1354334638&type=3&theater
Collapsed mount and cut through the shock and sleeve in the band saw.
http://www.facebook.com/photo.php?fbid=10152312616355174&set=pb.567395173.-2207520000.1354334638&type=3&theater
This is how the parts came apart and how the new mount is set up
http://www.facebook.com/photo.php?fbid=10152312570775174&set=pb.567395173.-2207520000.1354334638&type=3&theater
Welded and done. Had to crank the ark welder up quite a bit. Don't remember what it was set on but the shock is a solid piece of steel probably an inch thick.
Hope this helps. I had no idea what I was doing but it worked out well.
wondersmelonade
johnbigman2011
You should post that link in the parts resource section for everybody. Good site for sure
wondersmelonade
For sure!
Note for project sake : stopflex.com makes custom brake lines and hoses. Mine are too short with the drop spindles.
johnbigman2011
Dads are good for that... I miss mine for sure...
But look how we turned out!!!
