Date: 08/01/2018 01:27 pm
Date: 07/11/2023 11:39 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 06/07/2021 08:14 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 03/06/2017 01:24 am
  • Online today: 295
  • Guests: 187
  • Total: 187
Pinto engine trans question
Started by sedandelivery, September 11, 2012, 07:08:41 PM
RSM
You could also remove the yoke from the driveline and use it to plug the transmission. Just secure it real good so it doesn't get pulled out.
If you have a plug you can place in the tailshaft then you should be ok without draining the fluid. When you store the engine make sure all the ports are sealed up so that moisture & dirt doesn't get in & rust it. It's not required but I think it's a good idea. If you unbolt the transmission from the rear mount & the engine from the front mounts you should be able to pull it as a unit.
sedandelivery
I have a low mileage Pinto with an excellent engine with only 39000 miles. The body of the car is totally shot. I had the engine running yesterday, very sweet. Anyway I am contemplating removing said engine and trans from the car for reuse at a later time. Does the trans fluid have to be drained to remove the engine/trans assy? Any shortcuts others have used to remove engines in the past? The car is a 1980 2.3l, C-3 trans. How can you store an engine/trans. I would leave it in the car but I am needing the room.
