2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 04/14/2023 06:15 am
Date: 02/14/2018 01:34 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 09/01/2017 11:58 am
oldskool787
Date: 02/12/2017 12:42 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
  • Online today: 600
  • Guests: 379
  • Total: 379
1978 Pinto coil voltage
Started by hqtoyou, September 10, 2012, 07:31:17 PM
Call me at 330-307-6368 it will be easier than typing all this out.
Keith
So what's it actually doing on you? Shutting off randomly or running rough?
hqtoyou
All the parts that I replaced are new.
Were the coil & control box new or used?
hqtoyou
Nothing at all this car is bone stock from the factory. I traced the ground side, it comes from the ignition control module then from the coil it goes to the engine management module. Maybe the management module is bad and causing a short which in turn is causing a higher resistance than it should. I have replaced the following, distibutor,pickup coil,ignition coil,ICU,plugs,plug wires,distributor cap and rotor, all of which needed replacing anyway. The only other thing I can think of is I got the wrong coil and it has an internal resistor which with a electronic ignition it should not. but even so I should get better than 4 volts when running.
Quote from: hqtoyou on September 11, 2012, 07:03:56 PM
I'm getting 11.5 volts with key on and with wires removed from coil.
That's a little low but acceptable. Are there any wires tapped into either side of the coil like a choke wire on the positive side or a tach on the negative side?
hqtoyou
What's the voltage at the positive coil wire with the key on & the wire OFF the coil?
Yeah, if your voltmeter is accurate you have a problem somewhere. Even points ignition needs more than 4 volts.
hqtoyou
Thank you for the reply and I have another question if you can help me. I am getting just 5 volts with the ignition in run position before starting the car and 4 volts when the car is running. I assume that this voltage is to low to get consistant firing which right now this has been the problem, inconsistent firing to all cylinders.
I'm pretty sure all non-points Pintos take 12 volts on the positive side of the coil. Points cars cut that back to around 7-ish with a resistor wire or ballast resistor before the coil.
hqtoyou
New to this board "Please help" I need to know what the primary voltage should be on the coil while engine is running on a 1978 california pinto with stock electronic ignition. Thank you!
