Date: 11/29/2018 10:26 am
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 08/26/2018 06:23 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
pro stock front end
Date: 06/28/2019 07:43 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 07/04/2022 07:55 pm
Date: 07/30/2020 11:45 am
  • Online today: 295
  • Guests: 200
  • Total: 200
Manual transmissions schooling needed
Started by 1oldtimer, September 06, 2012, 08:38:20 PM
1oldtimer
Ok I have an EAO 2.0, what bellhousings will fit, what manual transmissions will fit and which are the best. I'm thinking about switching to a manual from the current C4 and know NOTHING about these transmissions. Also what flywheels, clutch arms and clutch set up will fit/work best. Will a stock trans be ok behind say a 150hp motor?.  Lastly, are the manual and auto trans the same dimension say from the block to end of bellhousing and from the block to trans mount...so I can keep the trans/motor mounts in the same spot and not hit the firewall.
Any info would be great and pictures would be better.....:).
Thanks
'72 2.0 in a '28 Ford.
