Radiator
Date: 05/27/2018 06:07 am
Date: 02/05/2020 11:06 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 06/24/2020 06:12 am
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 10/15/2017 10:03 am
1979 hatch needed
Date: 05/13/2018 08:52 pm
  • Online today: 531
  • Guests: 485
  • Total: 485
2.3L issue with idling
Started by MitchiePinto, September 05, 2012, 01:32:45 PM
MitchiePinto
UPDATE: Got the car running !!!!
The issue was the wrong power valve
In the kit it came with a 2 stage (I think) #28 power valve which made the car run rich and only stay running around 2000 rpm
I poped in my old power valve 1 stage #16 and fought with the float level until i got the smoothest idle
Now it idles around 500-750rpm (carb mixture screw's are set at 1 1/2 turns out )
No vacuum leaks, Car can handle slopes,loads and has no bogging or hesitating and the dieseling issue stopped
I have only the vacuum advance, PCV (from the air filter to the thing on top of the valve cover way in the back)
NOW one last issue the car has a mild lumpy idle like it wants to stall and if you listen closely you can hear a slight missfiring on idle and it vibrates some.
My hypothesis is that all this is being caused by the racing cam in it and I should check the ignition timing and advance the cam timing a little
Other than that the car is great it would do 100km all day long and Cruise fine its just the idle issue and I think it has an  overheating issue but im not sure. What are signs of overheating
MitchiePinto
When I bought the car it was hard to start and had a leaking carb and idle was lumpy but it wouldn't quit and would run ok at about 500-650 rpm idle
Now I rebuilt the carb it starts easy but I have to keep my foot on the gas until it warms up (takes 6 mins) it idles at 2000 rpm when cold then around 1500 rpm when hot
The carb mixture is set lean (If I ran it richer it would bog out) Idle speed is set around 1500 rpm if I set it any lower the car would stall improperly
I suspect a vacuum leak (Il check with propane)
My carb is a 2100 Motorcraft without a choke mech.
Also I have a racing cam put into the head everything else in the engine bay is stock
