77-78 front grill
Date: 04/07/2017 12:35 am
Date: 02/03/2018 11:28 am
Date: 10/28/2018 08:45 am
71-73 sway bar
Date: 06/12/2021 10:12 am
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
1977 Cruiser
Date: 06/29/2019 06:28 am
TWM Intake
Date: 08/15/2018 08:20 pm
Date: 02/27/2017 10:10 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
  • Online today: 447
  • Guests: 397
  • Total: 397
fuel restrictor question
Started by 78_starsky, September 02, 2012, 10:56:09 AM
5-7 psi should be fine. That looks like the pump I used on my tractor and it works good. If you have to much fuel pressure it will push fuel past the needle & seat and flood the engine. You should be fine with that pump.
78_starsky
hey guys,   no idea what a vane type is fred.  the pump i have is placed about 1 foot from the gas tank and the pump draws but pushes fuel instead of sucking. the psi is low 5-7 on this little pump so i will guess that it should be ok.
71pintoracer,  how will I know for sure if the pump is overcharging the fuel line and carb? needing to place in a regulator?
thanks
I can't bring that up large but is that a vane type pump ?   Fred    :)
Does it list the operating pressure? 5-7 psi is fine for a carb'ed engine, anything over that and you will need a pressure regulator. I use one on my car for the nitrous pump but don't need one for the engine pump.
78_starsky
hey all,  building the fuel system and placed in this type of pump.
mr gasket 35 gal/ph pump, and what i wanted to know ask is...  who is running an electric pump and did you use a restrictor to control fuel flow? and if so,  what type make or model?  using 2 bbl carb nothing extreme.
thanks
