Front grill for '72
Date: 03/02/2022 12:09 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 10/03/2018 02:00 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
door sills
Date: 03/14/2020 03:20 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
  • Online today: 535
  • Guests: 443
  • Total: 443
Motorcraft 2100 vacuum lines and power valve question.
Started by MitchiePinto, August 31, 2012, 05:33:56 AM
MitchiePinto
Solved my own question I had the idle screw out to much and vacuumed sealed the powervalve also putting the air breather on helped it run less richer. Still runs a little rich but I guess its because its such a big carb on a small in-line 4. Anyone else having trouble with the vacuum line routing use this link it really helped http://street2mud.com/webfiles/MC-2100%20set%20up%20for%20a%20258.pdf
MitchiePinto
This carb is on a 2.3L 1980 ford pinto with a PVC spacer and stock intake
Car runs bad on idle and I noticed all the vacuum lines were capped ? Only thing going to the carb is the fuel line
I noticed that the car has a vacuum advance hose, another somewhat big hose running under the intake from the block connected to a check valve (Check valve has two spouts) then tampered down to a long 5/8 hose, Some kind of plastic breather that's on the valve cover also has a big hose connected to it. That's all the hoses I could see at the moment oh wait theres also theres a stem that has about 3 inlets coming from the intake manifold the looks like it once was used as a vacuum but is now all caped off.
Motorcraft carb is also rebuilt but now one issue after mounting and cranking over I noticed that the power valve inlet leaks very bad ? Is gasoline suppose to come out off there? The power valve is brand new? Only thing I can think of is that I put the wrong gasket on (theres a round one and a triangle one). Should I just cap it?
Also where does all the vacuum hoses go, what are useless inlets that should be capped, does a hose go to the power valve inlet to a vent or something? etc etc etc..
Searching on the internet only gave me the answer of ( You should of marked the hoses before removing) But I bought the car like this with hoses all over the place!
Diagrams, info very much needed
Greatly appreciated need this car to run before winter
P.S ) I do not need emission junk or test for this year of vehicle
