Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 05/28/2017 03:20 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 02/21/2022 11:11 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 06/07/2021 08:14 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 03/25/2019 09:02 pm
  • Online today: 176
  • Guests: 128
  • Total: 128
V8 T-5 trans vs. 4cyl T-5 input shaft question
Started by 71pintoracer, August 29, 2012, 03:38:06 PM
Jerry merrill
I have a 95 t5 in my 65 mustang. The input shaft had to be changed to the shorter 93 and older, bell wont work, you will also need an older one.
Quote from: 71pintoracer on September 04, 2012, 01:35:51 PM
The diesel ranger pilot looks to be a perfect match. And....the local Advance Auto has one in stock!! Thanks for the info everyone :)
What's the part number? I'm debating running the 5.0 trans I have with a 2.76 rear gear in Callisto.
OhSix9
Fehrion,
yes it will bolt up. patterwise. watch the sn95 parts though. 94/95 they are kinda a redheaded stepchild as it is the new bodystyle before the went mod motor so it has some peculiarities. i believe it has a unique bell length to push the trans back so you might need a specific driveshaft and it may change shifter placement. should be a hydraulic clutch too.
OhSix'
Virgil to Sid
Fehrion_sit
asking a similar question, i want to buy a t5 from a 1995 5liter, the trans has the bellhousing on it. does anyone know if it will be cable or hydraulic clutch folk and if it will bolt up to my 67 289???
thanks for the help!
haha well it's a mis-matched pile of parts all thrown together so I may as well add some diesel parts to it! Thanks Mike, I'll look into that.  :)
Mike Modified
I believe that the (somewhat inelegant) solution to using a 4-cylinder T-5 behind a 5.0 is to use the Ranger 2.3 DIESEL pilot bushing/bearing (but don't quote me on that!).
Thanks old thats what I needed. Looks like the pilot end of the shaft is .008" too small for the v8. Hmmmm........now would be a good time to put a turbo 2.3 in this car and put the 5.0 with a v8 trans in the Cruisin Wagon........ 8)
Yea mine is a 4 banger trans behind a 5.0. Might not even be the problem. I think I will pull the clutch and bolt the bell up and take some measurments.
the v8 and 4banger input shafts are not interchangable.... the main difference is the tooth count which you found already..... the diameter of the input is the other difference... it can be machined down to the proper size for a 4 banger though for cheap......
I'm pretty sure I have read about this somewhere, the 4cyl shaft being shorter than the v8 keeping the shaft from going into the pilot bearing. When I built my car I didn't know the trans was from a 4 cyl car. It's been doing fine for years, but recently it started getting a vibration around 2500-3500. Our drivetrain tech said he thought it was the pilot bearing. Sounded logical since the trans had the shorter shaft. Pulled the trans and the pilot (roller type) looks perfect and there is no wear on the shaft. When I looked up a v8 shaft on e-bay, it stated that it has 23 teeth and is 9.3 inches long. The shaft I have has 19 teeth and is 9.75 inches. Now what? I was thinking that the shafts were interchangeable but.....?? Anyone have a v8 shaft they can get some measurments from?  :P
