Date: 07/08/2022 11:51 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Pinto drive train
Date: 06/29/2018 08:32 am
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 02/28/2024 02:07 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 488
  • Guests: 491
  • Total: 491
In the fuel tank mounted pump
Started by The Whistler, May 20, 2005, 10:40:15 PM
CHEAPRACER
I just mounted mine on the outside of the tank using a factory '83 turbo coupe pump. It's also the same fuel pump that fuels a later model 460 truck.
stonepony
I am at this stage right now with my 78 2.3 turbo swap my local rad and gas tank shop said it won't be a problem to stuff a pump and filter in the pinto tank  and then I can install a inline external  filter . External pump  might be alot cheaper though.
Runabout80
Ok. I see, I just buttuMEd too much there.
But I don't really see anything that would keep you from mounting the pump in the tank. Except for the fuel filter, if it mounts before the pump in the external application. But to fix that problem you could just use a sock-type filter in the tank on the pump and push the fuel through a secondary filter.
That just makes sense in my head though, as far as applying it in the real world, who knows.
But Holley makes an in tank pump with filter screen and all, I caught a glimpse of that in the newer Summit I got a couple of weeks ago.
1980 Pinto 2.3, Not much now but looking at a 400+HP 302 V8 heart transplant. In 2006 probably, too hard to afford stuff like that in College.
The Whistler
Sorry I did not state that the in tank pump was for EFI. I know most People mount the fuel pump external. But I not know of anyone who has put the pump inside of the tank for an EFI application.
Turbo is a way of life
Runabout80
I don't see anything stopping you from doing that, just tossing in a new circuit and relay for the pump... Although you'll need a fuel pressure regulator and to run a fuel return line. Otherwise you'll just horribly flood the carburetor anytime the pump is activated.
However, I'm assuming you're talking about putting the electric pump on a carbureted motor(be it a 2.0L or anything else).
It would be a good idea, although I don't know your ability or time constraints as far as this project goes. But good luck man and post up the results of it.
The Whistler
I am wanting to mount my fuel pump inside of the fuel tank in my 72 pinto. I want to know has anyone tried this before and had success? Any ideas or pointers are welcome!
