need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 10/11/2019 11:13 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 04/13/2017 04:56 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
v8 springs
Date: 05/07/2017 04:46 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
  • Online today: 628
  • Guests: 588
  • Total: 588
wheel rubbing
Started by dumcheesemonkey, July 20, 2012, 08:43:01 PM
Grumpy
Where is it rubbing, what size tires and wheels? Look at the splash guard inside the wheelwell, behind the tire. Or around the top ball joint or A arm. Or on the inside engine compartment bulkhead. There will be marks in these places if that is your rub. Also check your wheel bearings for excess wear and or loose bearing nut(a maintenance item anyway)
If it is rubbing behind the tire on your splash guard your strut rod may need bushings or a replacement altogether or tires that are smaller in diameter. Rubs on the top A arm you need a spacer or a larger diameter wheel. Rubs on the engine bulkhead can be cured by spacers.
Grumpy 8)
79 Pinto Hatch, Yellow w/White Pony stripes, Pony wheels, 6650 miles
dumcheesemonkey
i just bought my first pinto (green 79 wagon). Needs a bit of cosmetic work but for $500 a running car with only 30k is always good. Anyway, my tires seem to be rubbing while making a sharp turn (like parking). would i need to do a small lift to counter it or is there something else to try.
79 wagon 2.3
