I need a 1976 hood
Date: 12/19/2016 06:02 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 04/10/2017 07:30 pm
Date: 02/14/2019 06:27 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 11/11/2019 04:49 pm
Date: 03/13/2021 12:57 pm
Date: 05/18/2020 10:22 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 586
  • Guests: 427
  • Total: 427
master cylinder
Started by mrpinto73, July 11, 2012, 11:25:11 AM
That bail wire should take some serious pressure to snap over the cap. If it's not a tight fit try bending it to make it tight.
pinto21
You might try 2 gaskets cut out the center just use the thicker flat part of the gasket, makes a tight fit.
sounds like u need to replace the entire thing if it is stil leaking
mrpinto73
i put a new cap and gasket on master cylinder still have leak any help
Buford & Teresa Jaco Registered Ride #253
