Date: 10/03/2018 02:00 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 03/17/2019 10:15 pm
Date: 07/10/2016 10:17 am
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
Date: 10/27/2018 03:30 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 02/16/2019 10:46 am
  • Online today: 535
  • Guests: 453
  • Total: 453
C4 advice....new to them, a few question...
Started by griffon, July 04, 2012, 07:00:39 AM
griffon
Not sure of the rear yet.  Looks like an 8", it is five lug (front spindles are four), and it's locked up.  It could be welded so I need to get in there and see and do a driveshaft/tire count to determine ratio as I don't see any tags or any other I.D.  What's a good ratio?  I was thinking 3.23/3.55 would be a nice driving setup with the 3-spd.
RSM
It all depends on what your wallet tells you  ;D ....overdrive would be good for gas mileage. You didn't say what the car has for gears but if they are low the OD will make it nice to drive.
griffon
Called in a favor with a friend that has a trans shop, we put it on the rack and found several bellhousing cracks, took it out(after removing headers :-[) and found everything worn pretty good- clutches were about gone, hardened seals and generally due for an overhaul.  We are gonna try to match up some other options first though, possibly something with overdrive.  Or do you think I should stay with the c4?  I did some researching and my serial #'s are telling me that the carb, intake, motor and trans are out of a 67' mustang/cougar.
RSM
blink77
If I had a c4 that would only shift 1st and 2nd manually
I think I would be looking for a vacumn line to the modulator?
griffon
Thanks, I'll post results for future users.
Try adjusting the forward band in until it is snug then back it out 2.25 turns qnd see if it helps.
RSM
The C4 has no solenoids inside of it. Not having 3rd could be a band adjustment. Best thing to do is find someone locally who knows that transmission and have them look at it. A few bucks spent now could save hundreds if you have to replace it due to damage from being out of adjustment.
tpk
Its been many many years since I worked on the c4. I had an issue with no reverse and found the internal drum band had broke. I believe they have two of these bands inside-one for forward and the other for reverse. Normally when the clutches start to go bad you will have slipping  or it will take a long time to go into reverse. My c4 had bad clutches as well and I would back down my drive-very long driveway, to the main street. This would warm things up enough for me to have forward.
However, if you have a strong 1st and 2nd and no 3rd. It is probably something to do with the band. As for valve body that could be something as well. Not sure about solenoids inside of valve body but they impact shifting as well. I hope this feed gives some insight.
tpk
griffon
Just picked up a 71' with a v8 transplant w/c4 auto and am not getting 3rd gear.  It will shift manually 1 and 2 or seems to just drive in 2 with shifter in D.  Also takes a lot of fiddling to get reverse.  I'm new to these trans and am wondering if P.O. did something to the valve body or if there is some adjustment to linkage that it needs to be done?  Vacuum line looks good, ideas?  Any tips or advice on what to check for a new guy would save me a trip to the tran$$$. shop, thanks- Nate
