Pinto brake booster needed
Date: 05/08/2021 09:00 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 08/24/2018 02:50 pm
Date: 08/26/2018 06:35 pm
Date: 07/01/2019 12:23 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 03/27/2017 10:07 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
  • Online today: 489
  • Guests: 151
  • Total: 151
whats the widest 15" tire that will fit
Started by 80pintov8, July 02, 2012, 09:35:08 AM
earthquake
I.m runnin 265-50-15 on15x8.no interference problems but I am also using .250 spacers to center more in the wheel well.
racer99
My wagon has 295/50/15s on a 15x7 10 hole
Mustang wheel.I did use a .250 spacer to get the
tire off the leaf spring.
i cut the control arm mounts off the rear, matched the pinion angle of the stock rear and welded on a 22 dollar set of spring perches and bolted it up.....i did have a drive shaft made for mine but iirc a mustang shaft fits if you have a t5 swap done or a c4...also the rear from a thunderbird or lincoln is 1.5 inches wider than a fox mustang, i used mustang axles as said earlier to keep the wheels inside the fender..
80pintov8
My car has a 8" Mustang II rear in it, does a 8.8 rear fit? Just curoius on that, wouldn't mind going to a 8.8 rear, is it hard to make that rear work
racer99
Now,the entire tire is under the car when viewed from
above but approx. 50 percent of the tire isnt covered at the
front (rocker panel) edge of the wheelhouse.
same here with 5.5 backspacing on a 8.8 lincoln mk7 rear with mustang axles and drum brakes..
racer99
275/60/15 on a 8.5 wheel.
Can check back spacing for you.
Car does have a 9 in. Versailles rearend.
80pintov8
Whats the widest 15" tire that will fit a 80 Pinto rear, also need size rim with what backspacing
