Date: 01/10/2022 03:41 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 09/01/2017 11:58 am
Pinto Wagon
Date: 05/25/2018 01:50 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 09/15/2019 12:38 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
  • Online today: 403
  • Guests: 170
  • Total: 170
6G Alternator Question?
Started by dholvrsn, June 27, 2012, 08:54:56 AM
Attached are a couple links to 6G alternator vendors.  The first one has wiring diagrams showing two different available regulators.  If you have the one with the gray & black regulator, it should work as you wired it.  If yours has the white regulator, it may be designed for ECM control.
http://oldfuelinjection.com/?p=63
http://www.rjminjectiontech.com/collections/alternators/products/alt-8304
If you have the gray & black regulator, maybe the resistor that parallels the idiot light filament has a problem.  Good luck with the solution search.
I've upgraded Wee Beastie to a 130 Amp Sixth Generation Alternator. The thing works great!
Except.....
The alternator light comes on sometimes despite that the thing is charging. I'm always check my add-on volt meter to make sure.
I have a 6 gauge wire running from the alternator output to the solenoid. The yellow wire on the alternator connector is spliced the yellow and white wire also going to the solenoid. The green wire from the alternator connector is spliced to the green wire going to the idiot light. The old external alternator regulator has been eliminated.
I have but one WAG, which very well could be wrong, is that the internal electronics of the 6G are set up so that they are supposed to interface with an LED or electronics module, something with much higher input resistance than just a plain old filament bulb.
