postal pinto
Date: 06/03/2020 09:31 am
Date: 01/23/2017 07:41 am
Date: 04/13/2018 11:30 am
Date: 02/28/2018 09:18 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 03/30/2021 12:29 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 04/20/2017 10:10 am
  • Online today: 628
  • Guests: 521
  • Total: 521
Holley 390 cfm 4bbl problem?
Started by 72Wagon, June 26, 2012, 04:54:25 PM
72Wagon
Yes I did look and it has the ball with a brass weight on top of the ball, still getting pullover siphoning at higher rpms.  I site on the net said that the anti-siphoning nozzle helps but did not stop the siphoning on his 4cyl holley 2bbl set up.
I am going to try adding a tiny spring since it will be an easy attempt, and if that does not work I had suggested a steel weight in place of the brass.
1972 Wagon
71hotrodpinto
At one time i had the same problem on my exact setup. However its been so long i forgot if i ever solved this issue.
The 2000cc and the 390 carb end up having a very high inlet velocity which cause this problem.
Look and see if there is a Ball or a pointed rod underneath the Acc pump nozzle.
You want the pointed rod. Apparently its heavier and less prone to letting fuel by.
This is also an idea.
an " Anti Pullover Nozzle ".
http://www.ebay.com/itm/Holley-121-231-Anti-Pullover-Nozzle-/200722057521
Good luck!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
72Wagon
 I am running a Holley 390 cfm carb, and the problem I am having is that the engine intake vacum is pulling fuel from the accelerator pump squirters at higher RPM's. and causing an erratic miss.  The engine has a a stout camshaft which is not helping. If any one can help me cure this problem I would be a very happy Pinto owner.
1972 Wagon
