Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 12/31/2017 09:03 pm
Date: 12/24/2016 04:13 pm
Date: 01/28/2019 05:15 pm
Date: 07/20/2017 01:23 am
Date: 04/21/2017 02:03 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 04/07/2021 06:12 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
  • Online today: 452
  • Guests: 362
  • Total: 362
Is there a way to adjust a steel hatch?
Started by Pinto5.0, June 26, 2012, 11:51:31 AM
Thanks for the reply. I was hoping the roof holes were elongated already but I'll just have to do it myself. That overhang drives me nuts & I can't believe Ford built them this way. Oh well, just one more thing I have to fix on my list.....
postalpony
Hey P5.0---There is no adjustment!  Just holes in the roof panel. I have the same problem on my 80. One of the studs was stripped out in the hinge, so I repaired it by re-tapping the hole to 3/8 16  & using stainless all thread I cut & installed new studs in the hinge.  This also reduced the adjustment available, so maybe in the future I will have to elongate the holes to make the hatch fit.  Mine is just a cosmetic issue as I have a new seal on the hatch & it doesn't leak, so I may just let it hang out--I'm getting too old to worry about the small stuff.  I hope this helps.
                                                   Dick Mathias aka Postalpony
Now all we do is HAUL!
I'm not there yet but I want to plan ahead for this. My '80 hatch needs to go forward 1/4" or so to line up. My '79 hatch was like this as was another '79 I was looking at. They looked like Ford built them this way.
I'm hoping there is adjustment under the headliner but if not there will be when I get done. Those overhanging hatches look awful & it lets water in around the top hatch seal when the seal gets dry rotted.
