free transmissions
Date: 11/28/2019 10:21 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
71-71 speedo cable
Date: 02/18/2017 04:47 pm
Date: 12/15/2018 02:21 am
Date: 11/23/2017 05:44 pm
Date: 08/22/2018 09:23 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
  • Online today: 216
  • Guests: 258
  • Total: 258
drop spindles on a 73 runabout
Started by vonkysmeed, June 23, 2012, 11:17:18 PM
71hotrodpinto
The 73 from my findings are a draw of the deck. They changed over to the 74-up suspension mid year. So you never know what you have untill you check everything. The 71-72 has the rack that mounts on flat perches. The 74 and up has the 2 big bolts and bushings that are horizontal into the ground and go into the crossmember.
If im not mistaken ive actually "heard" that they mixed up some as well. 72 rack with 74 suspension.
Good luck! :)
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
I have not done this swap.  Based on my measurements, the 73 and 74  tie rod ends are the same.  Rockauto.com also shows the same part number for both.  The 71-72 are the ones with smaller tie rod ends.  This assumes no end of year carry overs.
Note that 74  spindles (including the drop spindles) are about 7/8" taller measured ball joint to ball joint.  If this is the only change, I believe this would increase camber gain during bump.  I measured the vertical distance from the lower ball joint hole to the spindle centerline with the following results: 72~2.5", 79~1.4", drop~3.4".  So the 2" drop spindles will lower the 71-73 cars by about 7/8" based on this.  Again this is based on component measurements and not on a final installation.
vonkysmeed
Quote from: pintoman1 on June 24, 2012, 03:21:20 PM
they will. i did it. the only thing i had to do was have the hole for the tie rod end reemed out to fit the taper of the tie rod. looks great on the car.
can you just use 74 tie rod end?
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
vonkysmeed
cool, will give it a try later this summer
73 Pinto Runabout
6 point cage
PintoMan1
1973 pinto runabout
vonkysmeed
will a drop spindle from a 74+ fit on a 73
73 Pinto Runabout
6 point cage
