Date: 02/11/2020 12:09 am
Date: 10/10/2019 10:02 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 08/03/2017 07:40 pm
Date: 08/20/2017 01:34 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 645
  • Guests: 548
  • Total: 548
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
nice looking setup! What headers are you running? I'll look into it for sure, the heater box has been out for 20 years! Do you have a better picture of the old '60's fuelie cover?
71hotrodpinto
 Hey 78, you should have room for the rear mounted fan if you run something like a CSR remote mount water pump ( if you can find room) . Just make a plate for the stock timing cover. Then tap at least 3/4 NPT into the locations over the inlet ports and use at least -12 maybe -16 type line from the pump.
Trouble is that you loose the heater ,( not that you'll need it with all the heat from that engine.! LOL  :lol:)
Thats kind of what i did on my setup. although i bought an ol mechanical fuel injection cover from the 60s for the SBF.
After all that you should gain about 4 inches over the stock water pump??? Whada ya think?
Heres a fairly current pic of my setup. It has allowed me to mount 2 10 inch fans behind the radiator and still keep some room in front of it. ( Hope it works well for me!)
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
talked on the phone, payed deposit by paypal....all is good! Thanks for looking out for me just the same!
CHEAPRACER
Quote from: 78pinto on August 14, 2006, 11:19:51 PM
I sold the 408 sunday, motor is coming out this week....kind of bitter sweet. A little earlier than i wanted, ending my Pinto driving season, but at least i got it sold. Ironically....a fellow on this site bought it! He found the for sale post through a search engine, and joined so he could contact me to buy it! It will reside in an '87 mustang in New Orleans LA. and be topped with a carb.
Just watch for the scammers.
the shortblock is being built now, i bought a Torker II 351w intake (low profile) to get ready for the carbed blow through set up on the VERY built 383 stroker. My goal is to be able to fit it under a stock pinto hood...or have a small scoop if nessasary....time will tell. I'll be using an electric water pump for room, moving my electric fan to the back of the rad, leaving room for my intercooler in front of the rad (i'm hoping).
Also, my 408 is for sale....i'll tear it down and go through it, i'll sell it complete with intake injectors and computer and loom, or part it out if i can sell the shortblock. Headers will be included in the sale of the complete engine. asking $6000 for the whole thing!!
dirt track demon
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
Brad...its a pinto, they break down....no other place to carry tools! ;)
Jeff, why do you have a nice shiney tool box sitting in the middle of your engine???? :o :o ;)
thanks!  Here is a current picture under the hood
took a picture of the pile of parts i have gathered for this falls 383 stroker turbo build. I'm considering going to blow thru carb set up.
My junkyard $150 351w F4TE roller block is in at the machine shop getting cleaned, and machined. I bought an Eagle forged 383 stroker kit last week..balanced and updraded to L19 rod bolts (didn't need to but it was the last pre balanced kit they had) the rotating assebly is now good to 1200hp! :o  too bad my block will crap out at about the 750hp mark! For heads, i'm leaning towards AFR 205's with 1.7 roller rockers and a Ford motorsport F303 cam (giving about a .550 lift with the 1.7 rockers) The wife still loves me, but this is my last engine she says....so i better do it right!
built the other megasquirt, its for sale if anyone is interested.
Hey 78pinto,
Thanks for showing your crack! ;D
i think they can fix it....a tube of JB weld and all will be well! :coolrasta:
As of now, i'm waiting for the local wrecking yard to pull the engine i'm going to be using for the new build out of a '95 full sized van. Its not shiny at all! Its a roller 351 Windsor and after teardown and machining (will be shiny then) will be the starting point for my 357ci turbo motor. I'll be using a Scat crank and rods, probe forged piston, Ford motorsport "F" cam and either my Dart Windsor Sr. heads or a set of AFR 185's depending if my heads are sold with my 408 stroker. I'm looking for about 500hp to the wheels on pump gas, and about 650hp with C16 and a increase in boost pressure and timing. The stock 351w block is good to about 750-800hp with good bottom end parts (including main girdle) as long as the RPM's are kept under 6500. The megasquirt is done and i just finished the new loom for it last night. For anyone wanting to turbo a 302, the block is weak and will crack around the 500 to 550hp range....even sooner if the tune is not right (detonation) see picts below.
For anyone who might be interested: I'll be selling my 408, complete or short block (i'll tear it down and redo all bearings so it will be fresh) I'll sell it with everything except the oilpan and pickup, including my EFI wiring loom and EEC IV (fuel injection loom and computer) Loom will be labeled for EASY hook up. Look for post in parts for sale area for more details. Here is the link, i know its not cheap.....but it comes with everything (you'll need Mustang II motormounts, an oil pan ect) including the '74& up 351 headers that have been ceramic coated.
http://www.fordpinto.com/smf/index.php?topic=4351.0
Quote from: 78pinto on March 30, 2006, 02:11:53 PM
its all Brads fault....damn shiny police :police:  ;D
I cant help myself............. :police:
gpinto2
Hey Jeff,that car is getting brighter(shiny) everytime you put a new piece on!!!!!!
1972 Pinto 410,C-4
hope to be there....if i can use the inlaws truck to tow it up there with!
Just got my new upper intake today, Downs box upper.....all ported and powder coated red (very shiny :police:). This will help me when it comes time to put boost to the engine.
dirt track demon
I hope the red rocket comes to carlisle, im looking forward to seeing this all done. Cant wait to see Tony's purple pinto, too.
The PINTO!!
Hello 78pinto,
I would like to read more about the mega squirt F.I. unit.
Can you LMK where to find info??
from Pintony
I bought another megasquirt set up off evilbay......i'm going to assemble and sell it, got a real good deal!
Quote from: 78pinto on March 18, 2006, 04:22:37 PM
i thought about it.....but i decided Brad will not be crawling up under my dash to see it so i don't think i will ;D
Um.........I think you have better take pictures of that so I can certify it " shiny" by the Shiny Police........ :police:................ ;D
