79-80 full glass hatch
Date: 01/04/2017 04:04 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 08/13/2018 02:46 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 03/18/2020 01:30 am
78 windshield trim
Date: 02/01/2020 08:46 am
Oddsnends
Date: 12/20/2016 10:52 am
Date: 03/29/2019 07:20 am
pintos for sale
Date: 12/11/2018 04:29 pm
  • Online today: 624
  • Guests: 349
  • Total: 349
ALUM. DRIVE SHAFTS
Started by bbobcat75, May 30, 2012, 08:01:32 PM
I have an early rear wheel drive aerostar DS in my 73.  The ends are pressed in so it makes it easy to shorten and press the end back.  I had mine welded to be sure that it would not spin.  The only thing I don't like about mine is that it is a 3" tube on the rear wheel drive vans where the AWD is the same diameter as the Pinto.
vonkysmeed is correct, the AWD is the same length and dia as the fox mustangs.  I am running one in my 86 Saleen.  The original driveshaft assembly weighed 16 lbs.  I reused the mustang yoke and axle flange piece because they were smaller than the van ones.  The assembled aluminum DS weighed 7 lbs when done.  Not a bad weight savings for $40 total.
vonkysmeed
fox mustang is a dead match in length.  i compared a 82 gt to the pinto
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
bbobcat75
well not going to work in my set up. 4speed with 6.3/4 rear, so if anyone is looking have one for sale, and is welded!!!! and like new. just asking what i had to spend for it 75.00
thanks
eric
and the u joint on the rear bolted right to my 6 3/4 rear,
1975 mercury bobcat 2.8 auto
OhSix9
awd Aerostar with a t5 and an 8.8 bolts right in.  didn't even have to change the yokes from the v6awd  van unit.  was 29.01 at the boneyard.
if it does measure only a half inch shorter than your original it will work fine there is lots of overlap in the slip yoke.  Word of note there are two shafts that come in those units an early and late part #  the late part # has welded ends and the early one is just pressed.  There was a recall on it so you may find the welded one on pre-96 models but avoid the ones with no welds  as they are known weak links.
OhSix'
Virgil to Sid
bbobcat75
has anyone had any luck on finding a drive shaft that is same or close to same and whats in are pintos??
thanks
eric
have read that awd 94-97 ford areostar rear shafts are only 1/2 in shorter
thanks
eric
