ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 09/06/2020 01:57 am
Date: 05/13/2021 05:29 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Seeking parts
Date: 10/18/2020 10:35 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 07/30/2018 04:32 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
  • Online today: 563
  • Guests: 263
  • Total: 263
Oil on underside of hood
Started by John Turner, May 28, 2012, 03:18:39 PM
RSM
The advantage to changing the seal would be that you get a look at the timing belt and tensioner. If its still got the original parts in it, wouldn't be a bad idea to change them out to prevent any breakdowns. It would even be a good time to change the crank seal.
JohnW
Keep an eye on your oil level and you might be fine. You could lose half a quart per oil change or 2 quarts a week, no way of knowing unless you check it frequently for a bit. From what I've sean when I had my valve cover off, it doesn't seem like the camshaft seal would be hard to change.
John Turner
72 Pinto Wagon, 2000 cc engine with 58000 miles.   When I began to restore this car the underside of the hood had a significant coating of "gunk" (grease like black crap, been there a long time.)  I removed hood, used a putty knife to scrape this grease like accumulation off.  Sanded hood underside to metal after major cleaning.  New coat of primer.  Noticed a new spatter of oil on the fresh primer.
My guess is it is coming off the cam timing pulley.  Sort of "cast off" the edge of the pulley.  I am guessing it is the front camshaft seal.  Two questions;  1) Is it a big deal to change out this seal?  2)  Looks like to me that it leaked for years with little effect.  Do I really need to change it?  jt
