  • Online today: 586
  • Guests: 236
  • Total: 236
Turbo mufflers , Any sugestions?
Started by Ruger Nut, May 24, 2012, 10:35:15 PM
johnbigman2011
Man That must be quite on the inside. 8)
Mike Modified
It's not bad....the Walbro is noiser at idle.  The turbo is louder when boosting.
It's hard to quantify  8)  I have perhaps 4 rolls of modern sound deadener installed.
johnbigman2011
Mike how does the Summit muffler sound?? Mellow or loud?
Mike Modified
Hey Mike what part numbers because you enter in Pinto it just shows stock stuff. I have a 1976 Wagon that's going to be Turboed soon.
Mike Modified
Summit sells inexpensive "turbo" mufflers the exact dimensions of the stock Pinto muffler (at least for my '77 wagon) with your choice of in- and out-tube size.
You can see the corner of mine in my 3" exhaust:
Running a Summit 3" cat also.
racer99
The hot setup is to go to a 3 in down and
keep it all 3 in with a straight thru muffler.
Keep to a straight thru muffler,no chambered type as it will kill
15-30 or more hp.
Ruger Nut
I'm running an 85 tbird 2.3l turbo, with the air to air IC tube, The factory T3 turbo , brown top injectors, 87 upper intake and throttle body, LA3 cpu, Lg VAM, 87 T5 , aerostar driveshaft, 78 Pinto 3.40 open gear 8" rearend from a 78 v6 Pinto . The factory down pipe is currently necked down to the factory(OLD) exhaust.  I'm ready to change today.
i agree with 99 on this... if its turbo you dont want any backpressure.... the turbo already provides this for you..... if you like it a little loud i run the napa 8"x3" race bullit... 60 bucks.... on dads turbo wagon we run a magnaflow and its a real nice mellow sound that flows great....just over 100
racer99
If it is a turbo car run a straight thru,non chambered,non
reverse flow type muffler.
Give me more info on the car.
Quote from: dick1172762 on May 24, 2012, 11:55:39 PM
Walker super turbo
in my humble opinion, can't beat 'em.  ;)
Ruger Nut
For now I'm going to run the factory down pipe,   Anysuggestions for the best sound and performance?  Thanks!
