Date: 10/01/2020 02:00 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 08/01/2023 06:53 pm
Date: 06/28/2019 09:14 pm
Date: 06/18/2018 03:47 pm
Date: 07/13/2018 02:21 pm
Date: 09/21/2018 11:35 am
  • Online today: 583
  • Guests: 349
  • Total: 349
2" Drop Spindles and 13x5.5" Cragars
Started by morpheus256, May 22, 2012, 03:46:49 PM
82expghost
it just depends on your offset, to run mustang 15s i had to use 1 inch of spacer, and while your front end is apart, get arp wheel studs, if you have new ballmounts depending on brand, they might rub at full lock. if you get the heidts bottom arms you wont have this problem.
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
Quote from: dick1172762 on May 22, 2012, 05:35:46 PM
If you ever have a flat, the lower ball joint will be on the ground.
That's an ugly thought.... I hope the 14 x 6 wheels I plan to run will avoid that with my drop spindles.
PintoMan1
yes you can run those wheels with the drop spindles, i did!
1973 pinto runabout
morpheus256
Hi!
I'm in the process of rebuilding the front suspension on the wife's 79. I've ordered in a polygraphite kit from PST, and a replacement set of stock springs from the. I was wondering if I would be able to run a set of 2" drop spindles with the 13x5.5 Cragar SS's up front.
I'm also trying to track down a set of Sway bar brackets for the frame rails, Hers never came with a front sway bar.
Thanks!
Dave
Bone stock 79 Runabout
