Date: 02/28/2018 09:33 am
79 pinto small parts
Date: 04/24/2019 03:16 pm
Date: 01/18/2017 05:35 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 10/25/2019 04:05 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 07/01/2019 12:23 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 06/18/2018 03:47 pm
  • Online today: 2,399
  • Guests: 1422
  • Total: 1422
1980 ESS Turbo Restomod
Started by Alpine615, May 21, 2012, 03:28:19 PM
Alpine615
Last night I installed the front stabilizer bar and upper and lower control arms. This afternoon I'm hoping to get the rest of the front suspension installed. I also think I found a suitable replacement bolt for the steering rack. Grainger sells all sorts of industrial strength hardware, which is exactly what I wanted; and not the crap from Home Depot.
1980 Runabout
Alpine615
Hi Bill,
Thanks for the info! I do still have your number, I will try to give you a call tomorrow.
1980 Runabout
blink77
Steve
I just did this and looked up the paperwork
#22-200 w/1-1/4 imput shaft. Includes inner
tie rods w/ 2 or 3 mounting holes-are interchangable.
It lists for 242.99 w/ a 91.00 core charge. I paid 115.00
from a friend in the business. He didn't charge me for the
core, but I owe him the old one or one just like it. It was
one of the nicest things I've done for my 79 wagon yet.
If you need more info call me. If you don't have my #
anymore p/m me and I'll send it to you.
Alpine615
I'm toying with the idea of getting a remanufactured steering rack, as practically everything else going into my car is new or rebuilt. I'm not 100% on it though...the money is starting to dry up.  :(
So my question is: does anyone know the length of the steering rack input shaft for a 1980? RockAuto lists three types for power steering racks:
- TRW gear with 2-1/4" input shaft
- Ford gear with 2" input shaft
- Unnamed gear with 1-1/4" input shaft
I think I read that 1978 and up use the Ford CII (or C2) gear, but that only eliminates one of the above choices. I suppose I could dismantle the unit I have and measure, but I'm not sure how easy or hard it would be. If someone were able to tell me that would save me some time and frustration. Any replies are very much appreciated!
1980 Runabout
Alpine615
Wow, it's been almost a month since my last post! I have been busy accumulating lots of parts that I need, including:
- 15" x 7" American Racing Ansen Sprint wheels with a 5 x 4.5" BC from Summit Racing
- 205/65-R15 tires from a friend's old car, just to roll the chassis around on; the engine is still a long ways from actually running
- 11" Mustang II Disc Brake Kit + SS brake lines from RJay's Speedshop
- Pinto/Mustang II control arm kit from Speedway Motors
- 45.5" Aerostar Aluminum driveshaft from local pick-n-pull + new U-joints and U-bolts from RockAuto
- Ford 8" rear with TracLoc posi and 3.25:1 gear ratio (I wanted to modify the 8.8" from the 88 TC, but time was the ultimate factor...I'll save that for my next project)
- New axle pads from ESPO Springs N Things
- New leaf springs from JC Whitney
- New shackles & hangers from CarParts.com
- Every kind of polyurethane bushing that Energy Suspension makes for the Pinto
- Rubber steering rack bushings & sleeves from RockAuto
- Help! steering coupler from AutoZone
- A front sump oil pan, oil pickup tube and various chassis and trim pieces from Fred Morgan (thanks again, Fred!)
- And finally, today I plan to order a rear disc brake kit from The Streetrod Manufacturing Company, minus the calipers and pads. For those, I'll be going to RockAuto again, as they are a bit cheaper.
Last night I tackled a problem that's been a major thorn in my side. The driver's side steering rack sleeve and bolt were absolutely frozen together; no amount of WD-40, P.Blaster, Kroil or even map gas would unstick them... So my buddy and I resorted to using a Dremel to cut up the length of the sleeve, and finally we were able to hammer the damn thing out. The threads on the bolt are horribly corroded though, and I'm not sure if it can be salvaged. This may be a stupid question, but where does one go to purchase replacement fasteners for the steering rack? I've looked through the ARP catalog, but they only appear to sell drivetrain-related fasteners...
I expect by the end of next week to have the engine and transmission mounted, all new suspension and brakes installed, and to mount those tires on my new rims. I am horrible at posting pics, but I will try to post some by the end of this week.
Cheers!
1980 Runabout
Alpine615
I found the old pictures I was looking for...
The first is a shot of my brother (sitting on bumper) and I standing in front of the beach house my parents rented one summer...
And the second is a shot of both Pintos (the one on the left is the one my dad was T-boned in) in our driveway... I wished I knew more about cars at this point, because I would've stripped so much more off the wrecked Pinto than the shop did, that's for sure...
(EDIT: This picture is pre-salvage. We got the hood, driver's side door, rear quarter windows, rear glass, lots of mechanicals and interior pieces, etc...)
1980 Runabout
Don't bother with NOS Ford ones. That nylon material doesn't like underhood heat & eventually crumbles. My draw thru turbo pipe cooked mine worse than yours was. The HELP parts are rubber & will hold up much better in the heat.
same here, help section and had to slightly modify it....
Alpine615
I was wondering if the "bushing" as I was calling it was sold separately, but now I have my answer. Thanks!
1980 Runabout
That WAS your steering coupler. It's also called a rag joint. Someone on here may know the part number but it's one of those HELP packages at the parts store. They have several different bolt spacings. The ones I found on Ebay required a minor elongation of the holes but thats no big deal.
Alpine615
Does anyone know what the orange bushing is called that is crumbling in my hands in the picture below? I took this picture while disconnecting the steering column from the steering rack. I've searched on RockAuto and can't seem to find it, but it is apparent I will need a new one!
Edit: Added a second image.
1980 Runabout
cool deal,,,,, youre golden then.......
Alpine615
Huzzah! Thank God I took pictures!
Had to rotate the image 180, but if you were to zoom in on the pic, the piston reads 'L2500F 75MM', which when looked up on the Fed Mogul site, comes out to be a forged piston. Whew!  ::)
1980 Runabout
me personally, im running weisco flat=tops BUT!!!! im running a standalone ecu and e85... so i have a way to tune for my setup... if youre using a stock ecu id look for a set of either diamond or cp pistons..... both are nice quality... cp is more expensive.... if youre using stock rods id just give them a call, most of their off the shelf pistons are for floating rods.....
speedpro pistons shown on summit havent been made for nearly 5 years now even though they show them on the site...... soooo.... take a look at what i suggested and figure what you can afford.... theyre gonna be near 500 with rings...
Alpine615
Quote from: Pinturbo75 on June 05, 2012, 10:50:50 AM
just a quick question,,,, i re-read your initial post and you said you did a 30 over bore.... what pistons did you use?  im hoping not hypers....... they are not suitable for a turbo app... even if the machine shop said they would work they wont.....so hopefully you got some forged ones in there....
Yarghhh, that they are. Chalk it up to inexperience at age 18, I guess... ::)
I just searched quickly and found a bunch of forged pistons at Summit, but I would gladly accept advice on the best brand/vendor...
1980 Runabout
Steve, it was great to meet you at Carlisle this past weekend. Dad & I made it back to Ohio just fine. The car is undergoing some brake work before I drive it again. Looking forward to hearing more about your car.  ;D
Alpine615
Thanks racer and pinturbo for your replies. Sorry for my delay in responding, but this is something I will definitely look into as it could save me a lot of $$$ over having a custom 8" rear built.
A quick update on my project:
I gave my Pinto a much needed bath about two weeks ago, and it's amazing how nicely she cleaned up. I somehow feel more motivated than ever to get to work on her, seeing her all shiny again.
I was also able to remove the strut rods by temporarily re-attaching the lower control arms and using my electric impact wrench. They appear to OK, only a minor amount of corrosion. Hopefully they'll clean up with a little bit of blasting...
...Which is why I recently purchased an air compressor and some tools so that I can blast the surface rust from some of the rear suspension hardware as well (upper and lower shock mounting plates, etc.) My intention is to get all those parts as clean as possible, and then have them powder coated. Once everything is coated, I'll swap in the new control arms, leaf springs and front & rear shocks. Polyurethane all around up front too...
Finally, to all of those I met at Carlisle:
Matt, it was a pleasure to meet you and your dad. I hope you made it back to Ohio safely...
Norm, it was good to see you on Friday. Although, where were you on Saturday? I didn't see you or the Boss Pinto and I returned to PCCA tent 2 or 3 times!  :)
Phil, I hope my contribution to the WWP helps, and seeing your "museum quality" Pinto was the highlight of the weekend...
To Harold, Skip and Bill, I know you aren't on the boards much, but if you read this, please know it was my absolute pleasure to meet and speak with you. I will definitely stay in touch for advice, encouragement, etc...
-Steve
1980 Runabout
like 99 said, you dont need to cut the axle,   just cut off all the mounts for the fox body control arms and weld on some spring perches....match the pinion angle of the origonal rear end and mount it up... with mustang drum brakes even the parking brake cables work..
racer99
You dont even have to cut the axle tubes.Our 71 IMSA RS Pinto
has a stock length Fox  7.5 under it. With the factory 10 holes
(15 x 7) we run a 9.5x23.5 cantaliever sidewall om them.
Alpine615
Quote from: Pinturbo75 on May 21, 2012, 08:47:50 PM
why not use the 8.8? i did in mine..... get the axles and drum brakes from a mustang, the mustang axles shorten the rear by3/4 inch each side..... either 7.5 or 8.8 the axles and brakes interchange between the two... strip the control arm mounts off it and weld on spring perches... that what i used...and im running 15x8 rims with 255-60-15s out back and they dont stick out the sides....its a good strong rear that is easy to get parts for...
Hey Pinturbo,
Where did you cut your axle housing? At the flange end or somewhere in the middle of the tubes and weld back together? It's been awhile since I've looked at my 8.8, so I'm wondering how you accounted for the axle bearings near the ends of the housing.
Also, as I mentioned earlier, I don't have the skills of equipment to cut and weld, so will any capable machine shop be able to do this for me? Or do I need to look for a speciality shop?
Thanks!
1980 Runabout
Alpine615
So I know I still haven't posted pics of my oil pan, but I'm thinking I'd like to ask around the board and see if anyone has an extra they'd be willing to sell. I will also create a post on the Parts Wanted forum. Please contact me at snatkins5@gmail.com.
Thanks!
-Steve
1980 Runabout
im running a pioneer deh-1800 atm. i will be adding 2 8in subs in the back of the wagon in subZERO boxes =D
Alpine615
Thanks 75bobcat!
I needed that thing in high school, as the factory AM/FM radio was crap. Funny thing is, I don't own CDs anymore! I do have an Alpine "media player" in my daily driver, that I will swap over once this car is up and running again.
1980 Runabout
nice wheels man. looks good for its age. tho i love the Alpine sterio =D
Alpine615
Unfortunately, even though it's been garaged for the last 9 years, it does have a little bit of rust in the places you'd expect... along the wheel wells, the rockers, and the corners of the doors. The underbody was coated in Quaker State MetalGard (the rear quarter windows proudly display stickers) so the floor boards are clean, thankfully. I know you've dealt with rusty floors, and that does not look fun at all!
There are some minor dents on the body from the previous owner, so I was planning on having work done anyway, this will just end up adding to the cost.  :-\
However, I know it could be worse...
1980 Runabout
Wow that car is sharp! Perfect dash is one thing but perfect steering wheel? Nice!! You got a real gem there. No rust I take?
Alpine615
Thanks Dwayne!  :)
Last night I tried getting the strut rods out but found that they just spin when unattached.  ::)  Tried jamming a spare tired in between the strut and the frame, but no go. I think I'll need to temporarily attach the lower control arm, and then bolt the strut to it, to get it out. Dumb mistake, should've loosened it first before removing the rest.
And come to think of it, the first photo might have been in the 2005 calendar,not 2004. I still have it somewhere, probably in storage.
Hope everyone has a great day!
-Steve
1980 Runabout
Nice looking car!  My family had a '79 Bobcat that color back in the day.
Dwayne :)
Alpine615
These will have to do for now...
There are others I am thinking of and they might be on an old computer somewhere.
This image was selected for the 2004 calendar, I believe... (photo taken at Valley Forge Park)
Pulled into the garage, ready for dismantling... (notice the TC engine block on the stand wrapped in a trash bag  :P )
I don't remember the driver's seat looking that bad...
Perfect dashcap and steering wheel...
30,563.3
1980 Runabout
