72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 01/19/2021 03:56 pm
Date: 02/18/2017 04:47 pm
Date: 03/13/2021 12:57 pm
  • Online today: 288
  • Guests: 269
  • Total: 269
how to remove seat belt
Started by redwinggirl, May 13, 2012, 06:13:24 PM
You're welcome, glad to be of help.  ;D  I will keep Stock Interiors in mind when it comes time to replace the carpet in my 77. It's always interesting what you find when you lift the carpet isn't it? That's cool you have a 78. I liked the design of the 77-78s more than the other years.
redwinggirl
Thank you! I just needed the right tool, amazing how that helps. P.S.. I got the carpet from stock interiors and it was an absolutely perfect fit. Funny when I removed the back seat cushion I found a Bubblicious wrapper, coins, a bag of faucet screens and what appears to be a joint! She must of been a fun ride.
There is the cover that goes over the bolt. I believe it is a torx t-45 or t-50 to remove it. I could recommend getting the torx bit set from the parts store. They come in a 3/8 drive so you can use your ratchet to remove it. The same size works for the buckle and the bolt that holds the belt to the floor.
redwinggirl
I'm replacing the carpet in my '78 Pinto and am having a problem figuring out how to remove the lower part of the seat belt assembly where in blots to the floor. Any suggestion/ help?
