1972 Pinto for sale
Date: 05/19/2021 12:41 am
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 10/14/2019 08:24 pm
Date: 05/28/2017 03:20 pm
KYB shocks
Date: 02/08/2017 07:09 pm
  • Online today: 502
  • Guests: 390
  • Total: 390
parts car
Started by jeff simmons, May 10, 2012, 10:08:42 PM
OhSix9
snag the glass,  just cut the rubber with an olfa knife and take it out easy. new seals are available online to drop it back in.   fenders and hood can swap over.  they are exactly the same unibody with revised fenders so you can make it an early model if you so choose. there is a good windshield polishing kit that comes with a felt buffer for an orbital and several rubbing compounds that you mix to a slurry,  it does a pretty good job on sandblasted glass but takes a lot of patience and elbow grease. A 8 or 10 inch low speed polisher will help speed the process
http://www.metromudd.com/Anodizing/Windshield-polishing-kit/
can supply the abrasive
Virgil to Sid
I don't blame you on that one. You should at least get the windshield if you have somewhere to store it. They are becoming scarce and it's good to have one around, as you never know what could happen when you are on the road! One stray rock from behind a long haul trucker can make your day go south real quick!
Just be sure you have the trim from around the pinch weld and having it glued into place with the trim will barely be noticeable of a change should that time ever come!
jeff simmons
I'll try the blue magic, I hate to replace a windshield that's not broken. Thanks
Did you try Blue Magic's headlight lens restorer? It worked on my 78 sedan's quarter windows. They were really cloudy when I first started driving it. I rubbed in some of the headlight lens restorer a few times and they cleaned up really nicely!
It will interchange if you cut it away from the body (cutting between the glass and the body, there is windshield adhesive holding it in place). Get the vinyl trim that goes between the glass and the inside of the car as well, it will fill in the gap on your car where the gasket is currently.
Pretty much everything will interchange minus the fenders and grill, and the head lights of coarse. Brian will know if I'm wrong here! lol :P
jeff simmons
I think I found my answer about the windshield,It won't work :( I still need a windshield, Can't find one in KC. Mine is real cloudy mostly on the passenger side hard to see through when shining in, I've tried all kinds of things to restore the glass, the cloudiness is just below the surface, Any ideas besides only drive at night ha ha
jeff simmons
I drove my pinto down to my friends machine shop, and he said he just bought a 77 pinto to take the drive train out of. I need to know what parts will interchange with my 80. I believe the front coils are the same, I cut mine to lower it now it rides to rough for me now I want to go on trips now need a smoother ride. Also the windshield, This one is mounted in a rubber seal, Mine is set on butal rubber, but will they interchange.
