Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 02/05/2017 09:45 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 09/22/2020 11:33 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Built 2.0
Date: 10/07/2018 05:27 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 531
  • Guests: 227
  • Total: 227
Please Help!! QUESTION?????
Started by FlawlessRacing, May 10, 2005, 09:34:26 PM
Quote from: CHEAPRACER on May 15, 2005, 10:38:02 PM
Don't forget the hammer.
Make that a BAMFHammer!!... got one of those... needed it to cram a 5.0 into a '74 Stang II. Talk about cramming 10gal of crap in a 5gal bucket!
CHEAPRACER
dirt track demon
Anything is possible with a mill and a lathe.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
CHEAPRACER
Quote from: dirt track demon on May 14, 2005, 12:12:01 AM
Quote from: CHEAPRACER on May 11, 2005, 11:01:21 PM
A 5 speed is a 4 speed with one extra gear for an overdrive.
  I wouldn't be so sure of that,  ford does offer 2 that 5th is 1:1
That fits a Pinto?
dirt track demon
The PINTO!!
the rear end is a 6.75 i believe......even worse than a 7.5
CHEAPRACER
(1) the rearend is a 7.5 inch, not the best hi-po setup. The gear ratios vary, somewhere there's a decoder for the door tag.
(2)The 2.0 bell won't DIRECTLY bolt up, but there are "offset dowels" & the option of cutting the dowels down in a lathe.
(3) If you pull the 80 bumper off you SHOULD be able to drill the bolt holes & install the early WAGON roll pans with no other mods on the back. The coupe roll pans won't fit, I don't think. There's some debate as to wether the early sheetmetal will fit the newer bodies. I'm of a mind that it will no problems.
As for the 4spd VS 5spd you might want to consult www.turboford.org there's a WEALTH of 2.3 turbo knowledge there.
FlawlessRacing
1.) What size rear, and gears are in a 71 Pinto coupe 4 spd.?
2.) Will the 4 spd. & bellhousing from a 71 Pinto 2.0 bolt up to a Turbo 2.3 out of a 89 Merkur?
3.) Will the rear rollpan & bumper measure the same if I cut my 80's out, and weld in the 71's?
I was wondering if the rear fenders mold in the same way, or will I have to mold or shape anything to match it up?
I'm ripping the 71 coupe's rear section off, and welding it up to convert my 80 wagon into a 71 Turbo wagon.
Any help on the above will help. I'm picking the 71 up Friday which I got for $50 without title. I also heard that a 4 spd. is faster than a 5 spd. because the turbo is pulling boost longer.
Thanks guys!
FlawlessRacing@comcast.net
Thanks,
Shane
