door sills
Date: 03/14/2020 03:20 pm
Date: 09/12/2018 12:33 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 01/21/2023 04:19 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
KYB shocks
Date: 02/08/2017 07:09 pm
  • Online today: 502
  • Guests: 391
  • Total: 391
Holley 185 cfm Pony Ram carburators
Started by johnbigman2011, May 03, 2012, 11:11:01 PM
johnbigman2011
Thanks for the reply 69. I'm really do like the looks of the twin carbs on the T for sure. I just want it to run good as well. I picked up a nice little motor from one of the members here on site so I'm hoping that it will run out alright. If not, I'll bolt on the the #6299 and with a  butterfly scoop for affects.
OhSix9
well the critical thing here is they are 185 cfm.  you could probably go with any pair of holly, autolite 1100s or carters yf's that you can make fit on the manifolds.  the only issue might be the need to get the thing run on a dyno to get it jetted. I suspect the original hollys where a bit on the lean side for the size of the motor vs the carbs.
Virgil to Sid
johnbigman2011
Has anyone on here ever had any dealings with the Holley R-6467 185 CFM carbs that were used on the Pony Ram intake from elderbrock in the 70's.
It seems that I can't find new or rebuilt ones anywhere. My 2.0 powered T bucket is going to be back on the road here in a couple of months and I'm sure these will be a show stopper in regards to it performing properly.
