Custom Pinto Project
Date: 06/12/2016 07:37 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 04/25/2017 12:17 pm
Date: 06/19/2018 03:58 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Date: 02/18/2017 04:41 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 01/28/2019 05:15 pm
  • Online today: 367
Badges etc.
Started by John Turner, May 01, 2012, 08:27:14 PM
Pangra74
I actually found plastic barrel nuts that worked on mine, no rust to worry about.
Joe
1974 Orange Runabout
Quote from: dave1987 on May 01, 2012, 10:10:52 PM
They use barrel nuts.
that is the factory correct option. However clear silicone works too, I use it and I do have a package of the nuts. Nuts chip paint and give a spot to rust (a friend pointed this out to me) and while not a big deal it was a consideration and why I use silicone. cover the post well, use some on the back side of the emblem, put it on, use painters tape to hold in place/setup and good to go. Both options work, up to the individual which they prefer. I will admit and this should be considered... I do find it easier to remove the emblems if nuts are used.
Alright, so I didn't order them, I bought them in town at a local auto paint and supply shop.
What they carry is called a "Wee Pak" and carries a small quantity of a type of fastener, in this case barrel nuts. The Wee Pak stock number is 99-876 and the description on the package is "Tubular clip 1/8" Stud Ford & Chrysler". It has worked perfect for my emblems and they are nice an tight now!
It looks like ebay carries them, not sure of the brand but I don't think it will matter.
http://www.ebay.com/itm/1-8-tubular-nuts-3-16-hole-size-100-pcs-emblems-/140477497527?pt=Motors_Car_Truck_Parts_Accessories&hash=item20b51c80b7&vxp=mtr
They use barrel nuts. I will check the size I ordered and post.
John Turner
I have a 72 wagon.  Prepping for paint.  Last paint job horrible.  The Pinto Badges and nameplates are all loose.  How are they held on??  (I was thinking of silicone adhesive?) jt
