postal pinto
Date: 06/03/2020 09:31 am
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 09/09/2018 03:22 pm
Date: 04/21/2017 02:03 pm
Date: 10/04/2019 08:43 pm
Date: 10/05/2017 02:26 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 577
  • Guests: 495
  • Total: 495
Gauges
Started by zappid, April 24, 2012, 07:05:29 PM
zappid
Since everyones been so helpful, I have another question for the group.  I want to pick up some gauges from my local pick and pull, just as a temporary solution to monitor my 79 Pinto.  Oil pressure and water temp, probably for sure... Maybe a tachometer?  The junkyard has mainly newer cars, some 80's and a bunch of 90's, the majority is GM, but there are also a good amount of Fords, nothing "fun" mostly average, daily driver, cars (Taurus, Sables, Escorts, F-150s, etc).  Anyone have any insight as to what would be the easiest removal and cleanest swap?  It doesn't have to "look" pretty, just function.  I'm sure I could get all three for around $10, so it's def. better than buying new...
I'm fairly certain I could install a water temp and tachometer, never done an oil pressure, but probably not out of the question.
Any and all insight is appreciated, as always.  Thanks again!
