  • Online today: 628
  • Guests: 548
  • Total: 548
4speed toploader with overdrive...
Started by dave1987, April 17, 2012, 07:36:22 PM
vonkysmeed
if an 82 gt and a 4 speed.  good chance it is a srod.  the 5 speed did not start until 83.
the srod is essentially an aluminum top loader with an overdrive of .71.
it works great behind my 351w
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
fast64ranchero
Call it whatever you want, some even call it a RUG,  it's still a top loader, it's still a 4 speed overdrive, 3rd gear is 1 to 1,  4th gear is 0.82 (if I remember right) ratio and it has a huge gear split between 2 and 3. is it junk? no, it's ok tranny. Would I use it behind a N/A 2.3? prob. not, I'd use taller tires,  a T-9 or a T-5
72 old V-8 parts Pinto
73 pinto, the nice one...
racer99
What is usually reffered to as a toploader is the Borg Warner trans.
Old school style shifter assy.
The SROD does also load through the top and it is a Tremac.
http://www.5speeds.com/toploader.html
fast64ranchero
Dave, it is a top loader, Ford made and installed thousands of SROD's and put then in everything from Fairmonts to Mustangs to Ganada's, with  4 bangers to V-8's it's a good stout tranny, I've use them in the past, the problem is there is a big step between 2 and 3, with 4th being a overdrive, it makes 3rd gear 1 to 1.  If it's real cheap maybe, other wise wait for a good deal on a T-5.
Walt
OhSix9
don't wast your time with that junk.  there are plenty of cable actuated t5's in fox body 4 banger mustangs from 87-94 that will pay off far better and give you a much nicer pick a gear.   Plus full blown t5 rebuild kits can be had for under 300 bucks on ebay
Virgil to Sid
racer99
Ford called the 5 speed a RAP,
No toploaders in 80s cars.
Got a parts breakdown if you need it,Dave.
Isn't the top loader a heavy trans, with big input/output shafts ?
I am going to use a super T-10 in my white car. Not worried about a 5th gear though.
If you want better milage, it would likely be cheaper to change the diff gearing.
I was initially thinking the same but the gear layout is the same as the stock Pinto 4spd, with the overdrive/fifth gear in the lower right next to fourth, which I found interesting.
There is an early 80s Mustang at a junkyard here with a 4 speed transmission and the knob has an "O/D" marking on it, so, an overdrive gear. Is this the SROD transmission I have heard of?
If so, I was thinking of pulling it and putting it in my 78 on the 2.3L motor, hoping to get some freeway cruising RPM back.
Right now I have the stock 4spd in the car with a 3.00 geared rear axle and at 65mph I'm pulling 3000 RPM, where as when I had the 2.73 gears in the stock axle it was pulling 3000 RPM at 75mph and 65mph was more like 25-2700 RPM (somewhere in that range).
