1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 03/30/2021 12:29 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
72 pinto
Date: 06/23/2016 12:40 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 07/11/2023 11:39 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
  • Online today: 367
  • Guests: 149
  • Total: 149
71 tie rod ends and leek help
Started by leakyred71pinto, May 07, 2005, 04:52:59 PM
leakyred71pinto
well thanks bunches, im sure i'll have more questions down the line. :)
Sounds like he did away with the emissions controls. If it runs good, then it's probably not a bad thing.
leakyred71pinto
thanks have another question the car had a fire under the hood so its not the stock carb (uncle bought and put on before i bought from him) and the airbox is gone so the vac lines are all plugged is this bad or maybe ok?
I don't think the 1.6 is related to the 2.0, but if it IS there's a TON of aftermarket for it. For a little boost in HP you can lean the carb a LITTLE & advance the timing, but be prepared to run 93 octane gas. A little lean helps build HP, a lot lean helps burn up pistons & valves. If you get ANY spark knock richen it back up immediately! (locals call it "valves rattling")
leakyred71pinto
does anyone know where to find 71 pinto tie rod ends looked everywhere cant find then. also i have a 1.6 in my car and was wondering if there is anything i can do to give the little motor alittle more pep. steep rodes are kinda slow goin. plus i went through a car wash yesterday and my FEET got wet! any idea where the leek is coming from?
thanks pinto fan
