Date: 12/10/2016 04:11 pm
Date: 08/26/2018 06:23 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 02/18/2017 05:55 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
  • Online today: 553
  • Guests: 250
  • Total: 250
Shifter Bezel Shaft Seal
Started by dave1987, March 29, 2012, 11:07:23 PM
5) New seal installed, viewed from above
6) Bezel back in the car
Here are some pictures!
1) Bezel before putting the seal in, actually it has looked like this since I got the car.
2) What is left of the old "seal" after cleaning up it's remains. Just the metal brace.
3) This is the new seal, and shouldn't deteriorate like the old one did.
4) The new seal installed from the inside of the bezel
It is forthe auto. I didnt know there was one for the 4 speed?
Thanks dave, is this for the 4spd or the Auto? I need the seals for the 4 speed
This is the seal that "wraps" around the shifter shaft inside the car. It is a split seal on the shifter bezel, mounted from inside the bezel, located to the right of the gear indicator. Normally the seal is made of an obsolete type of "rubber" and appears to be melted after sitting in the elements over the years. The rubber is VERY messy and hard to clean up, but once it's clean you will probably find the metal bracket held to the bezel with two rectangular push clips. The metal bracket was apparently what was used to form the seal to the shifter bezel.
I HAVE FOUND A SOURCE FOR A DIRECT PROPER REPLACEMENT!
SSC Enterprises (sscenterprises.com) is a Mustang II parts supplier, but the shifter bezel seal he has listed is the same one used for the Pintos!
I ordered one and received it today. I have it installed on the bezel and it fits PERFECTLY! I will post pictures tomorrow, right now it is to dark to get a good picture.
I will be contacting Scott (the owner of SSC Enterprises) to inform him that it truly does fit, and he will probably be listing it under the "Pinto Parts" section of his site afterwards.
