Date: 10/03/2018 10:46 pm
Date: 07/01/2019 03:17 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 10/26/2020 03:24 pm
Date: 03/05/2017 03:27 pm
Date: 08/16/2018 08:54 am
Wanted early pinto
Date: 10/03/2019 02:42 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
  • Online today: 600
  • Guests: 323
  • Total: 323
Removing Car Doors
Started by John Turner, March 27, 2012, 07:39:56 PM
I concur with both notes regarding weight of doors (surprisingly heavy) as well as the need for a second set of hands. When mine were reinstalled, we used a towel at the lower edge, set the bolts to medium tightness, and used a jack for upward/downward motion for alignment. Mine were particularly tricky because I removed the hinges completely from the door and the body to get them cleanly repainted, and rust removed from beneath. With all the guidance here you should be in fine shape.
Pintopower
You will also have to tap all the holes on the door before you install them. The original door bolts are crimped in place which renders them un-usable after they have been removed. They also damage the door threads. New bolts, thread lock and a tap will make the job easy.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
I drew around the hinges with a magic marker so I could line them back up when I put them back on. An extra pair of hands is a must to keep the frustration level down (not to mention chipped paint). The 72 doors are much lighter than the later doors with the crash bars but you still need help.
bbobcat75
you definatly want an extra hand or a door jack, these things weight a ton, look at the car, they are half of it, and it will take a little efffot to aline and get good gaps, but the time is worth it!!!
1975 mercury bobcat 2.8 auto
OhSix9
Doors are a first class pain to rehang. if your hinge bushings are good and everything is well aligned and your fenders are off drill locater pin holes through all 4 mounting points. 2 on the body and 2 on the doors then you can  get everything bang on.   otherwise start with a 3/16ths or 1/4 inch thick strip of wood on the lower door jamb to set the bottom gap even and then work the back gap even.  have a spare set of hands available.   make sure your doors are dressed as the weight of windows and stuff effects how everything lines up.
OhSix'
Virgil to Sid
John Turner
I need to remove and then reinstall both doors on my 72 pinto wagon.  Are there any special precautions or procedures?  (Seems pretty straight forward but if there are alignment issues I need to be aware of please tell me.  Thanks everyone.  jt
