Date: 07/20/2018 03:00 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 10/25/2019 04:05 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 02/28/2018 09:33 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 05/13/2021 05:33 pm
  • Online today: 548
  • Guests: 333
  • Total: 333
T5 tranny mount pics Anyone got any so I can see what I need???
Started by Ruger Nut, March 26, 2012, 09:15:29 PM
Here are a few pictures from my swap (T-5 in a 73 wagon).
1. The slotted and reversed trans crossmember. It was still tight at the rear and I had to flatten the edge of the washers to get the fit right.  Note that I slotted all the holes, including those that bolt to the unibody. I wanted as much flexibility as I could get.
2. I did not use the factory hole in the bellhousing for the clutch cable. I created a bracket that bolted to that hole. It helped get the cable above the crossmember.
3. A close up of the bracket. There is a slight angle to it that helps in regard to the cable/crossmember clearance. I did have to bend out the pivot arm on the bellhousing slightly.  Also, I welded on a little tab that acts as an anti-rotate if the bracket bolt ever loosened.
4. I'm 6 feet tall and like my shifter back far. I added this extension plate onto the shifter. I also cut and welded the shifter height to my liking. Not seen is the Murkur console I used. Also not seen is the tunnel cut you need to make for the T-5. The opening is too far to the rear and you need to cut about 3" forward.
Tom
CHEAPRACER
Ruger Nut
I'm trying to get the tranny mount correct.  Does anyone have pics of theirs??   Also how did you connect the Pinto clutch cable to the Bell crank T5 z arm??   Thanks
